Thuraya FDU- XT Fixed Docking Unit Logo
Hussien Ahmad Posted on Jan 11, 2014
I don't have connection between the Thuraya phone and the FDU-XT
I have Thuraya connection on the phone but when I dock it to FDU-XT, I can't make calls and don't have signal through the FDU-XT
Terry Du
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 10, 2014
Terry Du
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1164
Points
You can use The FDU-XT , because Thuraya XT can not use in the room , you can only receive the satellite signal outdoor . please see attached FDU-XT , Thuraya Docking station with outdoor antenna , which made by Huayang Technology , Brand Name : Matsutec.
www.huayang-tech.com
Why do I keep hearing a busy signal?
If it's a true engaged tone, the bluetooth speaker has connected to a telephone.
Lost GMA Card for Kaba ilco 780 FDU. How can i get another?
When you set up the system, you should have made at least 3 GMA's. Hopefully they did that and there are two other GMA's in a safe place. We keep ours locked up with the other key masters.
If you don't have any GMA's at all, you will have to call KABA. They will give you a reset code to reboot your FDU and then you can make new GMA's. You will have to remake all the other cards as well. It will be like starting over.
Good luck.
I continually loose my reception on my xm roady xt, i wiggle it around and then it works again, and so on. do i have a bad base unit and do they wear out over time. [email protected]
You need to resolder your antenna port on the dock connector. It's a really easy repair, all you need is a fine tip soldering iron. The antenna jack is on the right of the dock connector, it has 1 middle pin and 1 n-shaped pin that leads to 2 pads on the PCB. Your middle pin most likely has a cracked joint.
Does not work when docked in boombox,not getting
the "reactivate" did not take in it's entirety, try calling sirus/XM again and see if they will "reboot it again, this time try having it the docking station within antenna "range", and both should "reboot", let me know if this fixes the problem, if not I have some friends there I can call, and we'll go from there, god bless and happy 4th......
Overheats and cuts off
check the antenna and see if its grounded out anywhere, like if its chaffed and grouned to the car somewhere. If not try turning on the unit outside of the car or using it in the home dock, if it does the same thing its a problem with your unit or car dock
1helpful
Roady xt Antenna Problems
when it reads antenna it means there something wrong with either the connection or the antenna itself, it could be the location of the antenna or the antenna is going bad. if there is no obstructions on the car blocking the antenna i would advise purchasing a new antenna. you can get one at http://shopdelphi.com/consumers/satradio/xpressrc/
3answers
URGENT Belkin F5X007*****Please Read!!!******
same thing happened to me and I had to take the radio back to Walmart...
2answers
BelkBF5X007in XM radio boom box
Check your Conns both on Radio and docking Bay make sure Nothing Got on them .Clean them with alchol and Swab Good luck ttech
Top Thuraya Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Thuraya Cell Phone Expert? Answer questions, earn points and help others
