SOURCE: Water leaking out of freezer door water dispenser
The fill valve that supplies the water may not be shutting off completely. Also check to see that the lever is closing completely.
SOURCE: Ge profile side By side ice maker water leak
This sounds like the float mechanism has gone bad. Remove it and have a look. It may be the float or the switch on it that is bad. There is also a solenoid valve. Parts kits are available. Shut off the water first!
SOURCE: blocked defroster drain GE profile tfx25pr, tft25pr
Remove the freezer bins and shelves.
Remove the rear freezer panel.
The drain is on the bottom center of the freezer after the rear panel is removed.
SOURCE: GE Monogram refrigerator/freezer problem/ice dam in ice maker
I have had the same problem with ice forming. I found the problem is from the ice maker. The water fill tube delivers water to a plastic piece that acts like a funnel. The water goes through this plastic piece into the ice maker. Ice forms in the plastic funnel piece causing the water to overflow into the ice bin and freezer.
The type ice makers made for your model and other models require
no lubrication and are one of the most used parts of your refrigerator
especially if there is a large family and lots of ice used daily. They never
seem to stop working while the average refrigerator last 15 to 20 years the
average life of an ice maker is only 5 years. Even ice makers that have replaceable
parts the repair parts are more expensive in most cases than complete
replacement. Below is an example of an average ice maker that Whirlpool and
Maytag uses that have the Teflon coating in the ice slots. Your model is
for GE,=>
Model WR30X10093 Ice Maker and has electronic controls and no replaceable
parts. Thanks, Sea Breeze
