I have a top loading machine, a Maytag Bravos MTW6600. It's making horrible noises when it spins; I know the drum is off balance. I rearrange the clothes, but that doesn't help. Apparently, there's a sweet spot you have to hit to get it to spin correctly, and a 1 in a million chance of hitting that spot. I had the machine repaired in August 2013. The tech had to replace the water pump. Ever since that time, the machine will get off balance, I'll get a "UL" code, try to fix it and fail. It's taking twice as long to do the laundry this way!
SOURCE: Maytag Neptune Top Load Washer will not spin and
If your machine ius a FAV6800A LED console or FAV9800A LCD console then take a look at this post Clutch Fix if you want to DIY.
I will help you through the process. Your looking at $300 to $400 for a repair if you don't DIY. See if the DIY process is for you if so let me know I have a few additional questions......Rich
SOURCE: Maytag Bravos MVwX500XW0 Top Load Washer is not spinning
Check the inbalance/lid switch for continuity.Ck speed selector switch (if any)the water level and water temperture switches for proper opreation.NOTE:If any of the selector switches on the console are only poartially pushed in,it may cause improper function.I do not know how old your washer is.TEST LID SWITCH FIRST.If above does not solve,ck timer circuits for continuity.Get ready for this:there is to much to ck with out been there.is motor buzzing,test capacitor,washer spins but does not agitate,ck the agitator splines if they are not rhe problerm,the transmission might be the problem.GOOD LUCK.FYI I own Whirlpool washer and dryer and I repair my own,I prefer KENMORE/WHIRLPOOL/ROPER PRODUCTS because they are easy to repair and parts are not as high priced.
