The machine would not come on saying that it did not have water. The door was locked so I removed the kick plate and manually unlocked it. Now it has a fault code F1 and says the machine is blocked. I checked the self cleaning pump and it was clear.
The fault code F1 (or F01) is a Motor/triac fault. The triac is a device for controlling the relatively high currents required by the washing machine motor from the low power chips etc on the main Printed Circuit Board (PCB). Either the motor or triac has a short circuit condition. Check connectors on motor and main PCB card making sure they are sound and not lose. If the connectors are ok I would replace the triac or power board.
SOURCE: Dishwasher does not spray water
It sounds like your dishwasher is doing everything normal EXCEPT washing. The unit fills properly, the timer advances properly, the unit drains and goes through a rinse cycle, plus the water is heating. I would check your main wash pump for obstructions that may be clogging it, or if it is not running at all, you need to check the interconnecting wiring and/or something in the wash pump circuit that would prevent it from running. There should be a wiring diagram/tech sheet located behind the lower kick panel under the door. I hope this helps some. Good luck and let me know what you find.
SOURCE: Ariston Margherita 2000 AWD12 Advantage washer dryer filter clean
To clean filter, remove the lower plastic panel at front of washer.
Unscrew the pump filter cover anti-clockwise to remove and clean.
Please rate my fixya solution.
Thanks.
