Could be. No battery has a lifetime forever. But perhaps you did not unplug it correct?
Try plugging it in and look if any light goes on when plugged in on the charger. You don't need it on the charger for a long time. Then unplug it an try to start it again. also check if all contacts on the Jabra and on the charge cable are clean and nothing can block the current.
seeing the red light tells you that the jabra isn't fried or shorted and that there is life but there is a problem, the red light isn't blue when it should be. so have you read the directions your ear piece came with when you first bought it?... hold the on button until you see the blue light stays on.(blue light will flash fast then slow then come to a complete stop and stay on) once blue light stays on that should mean you can now find the ear piece on your cell phone to link up. if problem still isn't fixed then you might as well buy a new one.
bluetooth headsets are compatible with any phone that has bluetooth to connect just while its off, holding down the
power button untill a constant red light comes on. then searching for
the headset
From the sounds of this.. It's all due to bad keying of the polarized charging plug. The solid red light PROBABLY means you're battery is pretty darn dead. It'll need a new battery(not worth the cost imho. get a new jabra, and be happy once again) At a certain low voltage, the red light starts blinking. when it drops below the preset threshold, it will shut off completely. If it sits too long at this discharged rate, the battry WILL self-terminate. If the voltage drops below a certain level, it's ruined. Also note, most Li-ion cells will only last a few years. 2-3 years of "full power" is usual. Mine's 2 years old(steady usage), and showing signs of it's age.
"My red light won't go off even though I charged it all night. Also, a small piece of plastic came off the charge opening. I don't know if this is will pose a problem to the use of the Jabra BT150."
This is probably the most telling bit of information. It means you DID plug the charger in upside down. It will NEVER charge in that configuration, as it is supplying power to the completely wrong pins. If the battery was good to start with, it shouldn't hurt the headset, but never know. I have accidentily plugged it in backwards for a couple min before noticing, with no ill efect, but YMMV.
"Doesn't anyone from the Jabra manufacturer check this site?"
