My fridge released a chemical smell last night and a burning odor. It made alot of noise , so I unplugged it. It has no problem staying cold or making ice, no water on the floor. The only noise it has ever made for years is a knocking noise like someone was at the door. Im hoping that its not the compressor . Im assuming the smell is freeon. Of course its just out of warrenty.
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck [email protected]
SOURCE: Pervasive chemical odor
I was just recently having this problem myself (and I'd also encountered it long ago as well). Fortunately, I live in an apt. for the time being, so it was exchanged with another fridge after persistent complaints to the management. However, I did do a little sleuthing before the exchange ... and I did read something online where someone said (and pretty definitively too) that oftentimes "chemical smells" occur as a result of a coolant leak. Despite the fact that I did not physically see a leak, this explanation still made the most sense to me given the character of the smell.
So, your problem, like mine, is more than likely caused by an internal, occult leak. Also, not to worry you, but I would advise you not to consume anything else from your fridge/freezer until this is resolved since your food is being constantly permeated with this noxious gas circulating around it (and yes, even through the containers' small crevices). I ended up pretty much throwing out everything :( I am an RN, BSN by the way - we nurses usually have some pretty sound advice (even when it's bad - sorry).
SOURCE: Kenmore side-by-side has CHEMICAL SMELL ODOR inside.
You have a freon leak. With this only being 5 years old, iot's probably worth repairing, unless you are just able to buy a new one. I would have a local tech come out and check it before tossing it. I hope this answers your question and gives you some resolution. I hope to work with you again, so please record our name, email and phone number for future needs. Have a great evening!
SOURCE: We have a Kenmore Coldspot
It is probably your defrost cycle causing this. Obviously if you shut the water line off then it is not coming from there so there is only 1 other place it could be. Every 8, 10, or 12 hours depending on you defrost timer the refrigerator will defrost itself.......the frost melts into water and drains into a pan under the fridge. If the drain is plugged then it will just run into the refrigerator. If you have a freezer on top model then just remove the back wall inside the freezer, it will be a few 1/4 inch screws....If you have an icemaker then remove that too, it will be held on with 3 screws. Just look behind that wall and you will probably see ice at the bottom.....defrost the ice and pour a cup or 2 of water into the drain to make sure it is unclogged. If it is still plugged up then you have to find the clog....either in the back of the fridge behind the lower cover or in the refrig compartment near the back of the roof.
