SuperMicro SuperServer 7043M-6 (SYS-7043M-6B) Logo
h
hashemsafari Posted on Jan 11, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error in windows installation
When i try to install windwos xp i see error (0) atline 2161 d:\xpsp1\base\boot\setup\oemdisk.c. i have scsi hard drive
bill Sparton
Level 2:
Scholar:
New Friend:
  • Expert 82 Answers
  • Posted on Jan 11, 2014
bill Sparton
Expert
Level 2:
Scholar:
New Friend:
Answers
82
Questions
0
Helped
19389
Points
111
Not sure if XP will recognise SCSI as the primary drives. Under Linux no problem but most Windows OS's were never designed to support SCSI since it is more of a server drive system not a common home PC setup. I am not a MS fan and have not used MS products for many years so things might have changed. Remember XP is no long supported by MS so you might run into more problems down the road. I loved XP and changed OS's once the Vista/7 garbage took place.
Testimonial: "thankyou. but it support scsi driver before this i think that my bios have problem. i need bios for tower 6b but not found"
1 Related Answer
Ranger135xp
  • Posted on Dec 03, 2008
SOURCE: Need help on SuperMicro SuperServer 7043M-6!!
ok, all you have to do is reset CMOS. the same thing happened to me once I tried to install windows on my supermicro board. What you have to do is load the bootable CD that came with the board and follow the instructions in your book.
What happens is that windows does not have the drivers for the supermicro RAID and SATA components. The board will recognize these on it's own until you go to install windows improperly. Windows does not have the drivers for those, realizes it, and says "Windows has stopped to prevent damage" but it does it anyway. Just clear CMOS, read the book with the board on how to install an OS, and try again.
Clearing CMOS: This can be done by taking out the 3.5v watch battery you see on the board for about 5 minutes. Another and riskier way is to clear CMOS by shorting the pads. On a diagram of your board, you should see CMOS Clear. Find those two pads on you board in that general area from the diagram. You'll know you've found it because the board has CMOS Clear printed near them. Just touch them with a screwdriver for 5-10 seconds. CMOS should be clear and ready to start new.
WARNING! Be careful when clearing CMOS with the pads, if you stick the screwdriver in the wrong place, you could damage your board. Be sure to unplug your power supply before working on your machine (I'm sure you know this.) and be sure to get the correct drivers for windows this time! Oh, and rechange any settings you changed in CMOS since it has been reset to the factory defaults.
1helpful
Dual boot xp with windows 8
No solution now, Install Windows XP again on first partition, Make sure BOOT.INI, NTLDR, NTDETECT.COM in the same partition in which Windows XP is loaded. Then install WIndows 8.
OR in the current scenario you've to do much technical work using third-party tools.
tip
How-to repair Windows XP, How to Perform an In-Place Upgrade
One of the best kept secrets of Windows XP is it's built in repair feature!
In previous versions of Windows, correcting an operating system error, or installing a new motherboard, usually meant formating and reinstalling, resulting in loss of all data. Don't worry; Windows XP repair feature won't delete your data, installed programs, personal information, or settings. It just repairs the operating system!
Why would I want to reinstall Windows XP?
1) Can't start Windows XP in safe mode.
2) You have problems caused by a recently installed system update (Windows Update, hotfix, Windows XP service pack, or Microsoft Internet Explorer update).
3) Your problems can't be solved with system restore, or you can't access system restore.
4) You've installed a new motherboard, or made other major hardware changes and need to reinstall Windows.
Let's get started!
Step 1: Rule out hardware issues. Windows Repair will only fix software problems. Hardware issues can also cause boot problems (i.e. bad hard drive, memory, CPU, or power supply).
Step 2: Backup. It's always a good idea to backup your important data before making changes to Windows XP. Relax, if you follow these instructions your data will be perfectly safe.
Step 3: Boot from your Windows XP CD. Insert the Windows XP CD into your computer's CD-ROM or DVD-ROM drive, and then restart your computer. When the "Press any key to boot from CD" message appears on the screen, press a key to start your computer from the Windows XP CD. Can't boot from your CD? Please see the note at the bottom of this page (Configuring Your Computer to Boot from CD).
Step 4: A blue screen will appear and begin loading Windows XP Setup from the CD.
Note: RAID/SCSI/Unsupported UDMA users:
You will be prompted to "press F6 to install any third party SCSI or RAID drivers". Most users will not have to press F6, but if you are running RAID, SCSI or unsupported UDMA controllers, then you will have to have your controller drivers on a floppy disk. If you are unsure whether you have RAID/SCSI, then simply let the CD load without pressing F6.
When completed loading files, you will be presented with the following "Windows Setup" screen, and your first option. Select "To set up Windows XP now, press ENTER". DO NOT select Recovery Console.
Note: The system repair function will remove any updates you have previously installed that are not included on the CD. Drivers will also be reverted to their original XP versions, as well as some settings (network & performance settings may sometimes be reset to their defaults). It may be necessary to reactivate your Windows XP as well. When finished, you will have to download all of the updates from Microsoft Windows Update, because they are all replaced during repair.
Let's get started!
When presented with the screen below. press the F8 key to continue
Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation, or install a fresh copy of Windows XP.
If no installations are found, then you will not be given the option to repair. This may happen if the data or partition on your drive is too corrupted.
Note: If you install a fresh copy, all data on that partition will be lost!
Your almost finished! Windows XP will appear to be installing itself for the first time, but it will retain all of your data and settings. Just follow the prompts, and have your CD-KEY ready if needed.
Do you have more than one system, or lost your CD-KEY? Visit the keyfinder page to retrieve your CD-KEY.
Update: Due to the proliferation of the Blaster and Welchia Worm/Virus be aware that a Repair Install will leave your system vulnerable. You can get infected within seconds. Do not go on line until you have enabled XP's firewall first.
Remember to run Windows Update! (install critical updates first)
Many computers are not configured to boot from the CDROM. If you cannot boot from the CDROM, this is probably due to the boot order of your devices being incorrect. You can change this in the BIOS.
You enter the BIOS from the first screen you see when you turn your computer on. To enter your BIOS, most users here will press the DEL key.
Most Dell, Toshiba, Gateway, Sony & HP systems will press F2.
Compaq users will usually have to press F10.
IBM typically uses F1 or F2.
Other brands may have different keys to press to enter setup, F1, F2, Del, Tab and CTRL+S. If possible see the manual for your computer or motherboard. Also, the BIOS will usually display which button to press to "enter setup" during POST (if it flashes by too fast, press the Pause key).
When you enter the BIOS setup, you need to change the boot order. The CDROM should be setup before the Hard Drive. Each BIOS is different, but here is an example:
on Jun 18, 2010 • Computers & Internet
Windwos instalation
You are missing updates to the OS.
When i start my pc today, i had stop 0x0000007b (0xf9e48528 0xc0000034 0x00000000 0x00000000) i try with chkdsk /r end fixboot but no result.
When you start your computer, you may receive one of the following error messages:
  • STOP: 0x0000007B (parameter1, parameter2, parameter3, parameter4)
    INACCESSIBLE_BOOT_DEVICE
  • Setup has encountered a fatal error that prevents it from continuing.
    Contact your product support representative for assistance. The following status will assist them in diagnosing the problem.
    (0x4, 0x1, 0, 0)
    Setup cannot continue. Power down or reboot your computer now.
You may also receive a "Stop 0x0000007B" error message during Windows XP Setup when the Setup program restarts during the installation process. When you receive a Stop error while the Setup program is running, you receive the second error message. To troubleshoot this issue, read the following four sections to determine if any one of the issues applies to you. If none of the issues apply to you, use the following general troubleshooting steps at the end of the article. uparrow.gifBack to the top Boot-Sector Viruses You may receive a "Stop 0x0000007B" error message if your computer is infected with a boot-sector virus. If the problem is intermittent and you can start Windows, check your computer for viruses. If you find a virus, also check any floppy disks for viruses before you use them again.
For a list of antivirus software manufacturers, click the following article number to see the article in the Microsoft Knowledge Base: 49500 List of Antivirus Software Vendors Note You may have to use more than one brand of virus-detection software to detect and remove various viruses.
Important If your computer has been infected, it may be open to additional forms of attack. We recommend that you rebuild infected Internet-facing servers by following the guidelines that are published on the CERT Web site. Internet-facing servers are servers that function without a firewall or other protection. It is also a good idea to rebuild any other computers that are at risk because of their proximity to infected computers before you put them back in service.
If a virus has infected your Windows XP-based computer and a virus-detection program cannot remove the virus and repair the system, you must repartition and format your hard disk and reinstall Windows XP. For additional information about partitioning and formatting a hard disk with Windows XP, click the following article number to view the article in the Microsoft Knowledge Base: 313348 How to partition and format a hard disk in Windows XP For more information about how to help protect the boot sector from viruses in Windows XP, click the following article number to view the article in the Microsoft Knowledge Base: 122221 How to protect boot sector from viruses in Windows uparrow.gifBack to the top Device Driver IssuesYou may receive a "Stop 0x0000007B" error message in the following scenarios:
  • A device driver that the computer boot controller needs is not configured to start during the startup process.
  • A device driver that the computer boot controller needs is corrupted.
  • Information in the Windows XP registry (information related to how the device drivers load during startup) is corrupted.
Windows XP requires a miniport driver to communicate with the hard disk controller that is used to start your computer. If Windows XP does not supply a device driver for your controller or if Windows XP is using a corrupted or incompatible driver, you must replace the driver with a valid copy that is compatible with your controller and Windows XP.
During the first phase of the Windows XP installation, Setup displays the following message at the bottom of the screen: Press F6 if you have to install a third-party SCSI or RAID driver. Press F6 and then follow the instructions to install a mass-storage device driver from your Original Equipment Manufacturer (OEM). For additional information about using F6 to load an OEM device driver to support, click the following article number to view the article in the Microsoft Knowledge Base: General Troubleshooting If none of the issues that have been described in this article apply to you, use the following general troubleshooting steps:
  1. If you receive one of these error messages while you are installing Windows XP, update the computer BIOS or obtain Windows XP drivers for your hard disk controller (from the manufacturer of your computer, system board, or hard disk controller), or do both. For information about how to update your computer's BIOS or obtain Windows XP drivers, contact your computer manufacturer. For additional information about the availability of drivers, see the Device Driver Issues section in this article.
    Note: If Windows NT 4.0 or Windows 2000 was installed previously on a mirrored boot partition, see the Other Issues section in this article.
  2. Use the Last Known Good Configuration feature. This may resolve the problem if you recently installed an incompatible device driver for your boot controller. For additional information about using the Last Known Good Configuration feature, click the following article number to view the article in the Microsoft Knowledge Base: 307852 How To start your computer by using the Last Known Good Configuration feature in Windows XP
  3. Use the Repair option with Windows XP Setup. For additional information about repairing Windows XP by using the Setup program, click the following article number to view the article in the Microsoft Knowledge Base: 315341 How to perform an in-place upgrade (reinstallation) of Windows XP
  4. Restore a registry backup. For additional information about restoring a registry backup, click the following article number to view the article in the Microsoft Knowledge Base: 307545 How to recover from a corrupted registry that prevents Windows XP from starting
Error "Setup didn't find HDD"
Well, first of all XP is not the latest supported operating system from Microsoft.
That being said, I have not had a garbled screen followed by an error message 'setup didn't find any hard disk drive installed' on a laptop, in my limited experience with laptops (i.e. Acer One, Acer Aspire, Sony Vaio, etc.)
If you have an unexpected garbled screen it points to the pc board or mother board or the video card, but more likely the motherboard.
And, if you couple this with the hard disk drive not being detected, it reminds me of a situation where I had a no hard disk drive detected on a SCSI drive connected to my Windows 95 computer in the 1990s when I had heat related issues with the circuitry on the hard drive getting burnt out capacitors.
If the drive is not recognized, it might mean the boot sector is wiped, and essentially it needs to be reformatted and the operating system needs to be reinstalled (which you evidently tried to do).
To my memory, I never had this problem on Windows XP with a laptop, so I am thinking it's not Windows that is at fault, but the physical hardware is giving you problems.
If you boot from the CD for Windows XP and it doesn't find the drive, it's a big problem for this laptop.
I wish you luck in finding an answer to that one, seeing that it's out of warranty and XP is no longer supported by Microsoft.com.
I can not install Windows on my Compaq Evo N620c
The quickest solution here would be to put the hard drive into a computer that has Windows already running, and format it through the operating system itself. I've run into this problem a few times, and when another computer wasn't available I would use a Linux boot disk to clear out all my partition tables, then I would load up with Windows XP and tell it to write a new NTFS partition. Do NOT select the 'quick format' option, you'll have to wait through the long one.
Pci ide controller for third hard disk
You need to enter into scsi bios first, then do an autodetect for hard drive, this will set the IDE/SCSI hard drive on raid controller.
To enter SCSI control you need to press the same key stated on screen on startup (F6 I assume) I think F3 is just boot settings.
If the card do not enter regularly in CMOS settings for the raid then this card is defective.
Rathwynn
Hey there
The most common cause is that setup does not have the driver for a SCSI device or is detecting storage devices in the wrong order, such as that CD-ROM drive first.
Press F6 when setup first starts and provide a driver for the mass storage device that will hold the operating system files.
Check to make sure all adapters and controllers are working properly.
Check power to all devices. Reseat adapters and controllers.
For SCSI devices ensure:
1. The SCSI cabling is properly installed.
2. SCSI devices are terminated.
3. SCSI devices are correctly addressed. And
4. The BIOS correctly recognizes all SCSI adapters.
Also, be sure the SCSI boot drive is addressed as 0.
Check the manufacturer's recommedation for configuring SCSI adapter and Hard Disk Drives. Try replacing the adapter before replcing the drive(s).
For EIDE Drives:
1. Check the controller.
2. Ensure file I/O and disk access are set to standard. And
3. Ensure that the system drive is the first device recognized by the controller.
For IDE and ESDI drives:
1.Check the cabliing and controller.
2. Check the Drive setup in the BIOS for master/slave relationships. And
3. Ensure the drive is properly recognized in the BIOS.
Gimme acknowledge by rating me.
thanx
Romy
IBM IntelliStation Z Pro 6221
Mayeb you need to repair the OS - In which case you will need to have SCSI Controller XP OS floppy driver obtained from IBM website.
Start up the computer booting up from the CD ROM. Then when it comes to "install thrid party devices" - press 'S' and insert the floppy with the SCSI Coontroller on it and follow the on screen instructions.
Windows Xp on Intellistation Z Pro type 6221
A restoration disc is not a conventional Windows OS disc (and vice versa), therefore it often cannot be used as if it were a true Windows disc. The restoration disc includes the OS, but it also includes every driver and other software product that came with your system. If Windows were the only item loaded on your system, then a Windows disc could serve as a restoration disc, but these days, using a typical restoration disc is an all-or-nothing process.
A restoration disc is your ultimate troubleshooting tool. Suppose that your copy of Windows becomes damaged from a virus or key applications become corrupted. Symptoms such as instability, crashing, indecipherable error messages, and impaired performance are extremely hard to diagnose by yourself—even if you have the help of a customer support technician on the telephone. If the most common corrective steps fail, you can always use the restoration disc to recover your PC back to its known-good, factory-fresh state.
Top SuperMicro Computers & Internet Experts
Julie Clark
Julie Clark
ADMIN Eric
ADMIN Eric
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
