My hubby washed my percolator and submerged it during cleaning. Now when I plug it in nothing happens. Any idea what is broken on it? is it worth replacing parts, or should I just buy a new one?
If the coffee maker remains cold, the switch or the thermal cutout inside is bad. If nothing at all happens (no light, no heat), you may have a damaged power cord. Power cords may break at the plug if people yank on the cord instead of the plug to unplug the appliance. Sometimes the cord breaks where it goes into the pot if jammed hard against the wall or otherwise bent or twisted sharply there.
If you get heat but no percolation, look for clogged plumbing, such as lime buildup or a piece of paper towel in the percolator tube.
USING YOUR PERCOLATOR
1.Wash the Percolator thoroughly before using for the first time.
(See "Cleaning Instructions" section in this manual.)
2.Remove Cover, Basket, Spreader and Pump Tube. Use cold, fresh
tap water to fill Percolator. Fill according to markings on inside
of Percolator for number of cups desired. Use cold tap water -
the automatic brewing cycle is timed to begin with a cold
water start.
NOTE: The bottom of the Pump Tube Spring marks the maximum
capacity of the Percolator.
3.Wet Coffee Basket to help keep small particles of coffee from sift-
ing through. Place Basket on Pump Tube. Add desired amount of
regular or percolator grind coffee to Basket.
4.Place Pump Tube with Basket into Percolator so bottom of tube is
set into Center Well. Place Spreader on top of Basket and snap
Cover onto Percolator. Attach cord to Percolator and plug into
standard household 120 volt AC wall outlet. Brewing begins
within seconds and continues at a cup-a-minute speed
5.When coffee brewing is complete, percolating will stop. The
Percolator automatically switches to "KEEP WARM" setting to
preserve fresh-tasting coffee at hot, ready-to-serve temperature.
For best flavor, remove Coffee Basket, Spreader and Pump Tube
when brewing is completed.
The holes you showed in the first video before you fixed the machine are there to install bolts to stabilize the barrel during shipping and storage only. They are off during normal use.
We have a Farberware Percolator / "Superfast" #FCP412-A...This morning we plugged it in and nothing happened...I took the base off and found one of the connectors loose, but not totally disconnected. After I tightened it, we plugged it in and it still did not heat up. Any suggestions would be appreciated. Thank you. / JP
I thoroughly cleaned my 4-cup percolator by brewing a couple of pots of plain white vinegar and scrubbing the build-up from the bottom of the pot (and running a couple of plain water brews through the pot after all the cleaning). The percolator now brews hot, strong coffee again!
Beleve it or not, if you want to clean a clogged coffee machine, add to the well a cup of white vinegar (inside the water reservoir), with no water, and let it work to percolate the vinegar. The fumes are bad but it will unclog the filtering. Be sure to put water (no coffee) and percolate with no coffee at least 3 times and you have a clean coffee machine.
Thanks for letting us know that there was no solution other than one I would have to come up with entirely on my own. My dad who is old school wouldn't let me give up so we took the thing apart and it was an easy fix. Take the 5/16 nut off the bottom. Pull the slide pins off the thermostat. Take the philips screw out of the support holding the thermostat in place. Use a sharp pointed knife and with the silver Aluminum cap flat on the bench, make a slice on one edge. Use the knife to pull the edge away from the plastic housing and the cap will pop off. Be careful not to loose the small piece of ceramic that lies in a small whole on top of the contact. Use a sharp knife to clean the contacts and check with an ohms meter or continuity light. If it makes a good contact, put it back together. It took my dad and me about 10 minutes to do the entire job. We looked for a part for 20 minutes. Good luck. Rick and Adam Schmitt of Maryland.
Try reseting the configurations. It has a small hole in the front of the cammera you can put a pencil on it when you start it up. I had some trouble to start it once, but it shows something on the LCD and the green light blinks. If thats your problem the pencil in the hole will fix it.
