Citizen Skyhawk Eco-Drive JR306059F Wrist Watch Logo
A
Anonymous Posted on Jan 10, 2014
Cannot. Get. Second. Hand. To. Move. Off. Zero
Brand. New. Watch. I. Have. Tried. To. Set. Chronograph. And. Alarms. With. No. Luck. Large. Hand. Has. Not. Move. Once
5 Related Answers
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Dec 17, 2008
SOURCE: Second hand seconds out
This definetely is NOT a fault as all modern watches are fully adjustable unless damaged.
All resetting functions should be in your watch manual. Just follow step by step and the problem should be solved.
In case you've lowst your manual:
Go to www.citizenwatch.com find technical support and your exact watch or by caliber number.
Good luck
Arthur
Anonymous
  • 2501 Answers
  • Posted on Feb 01, 2010
SOURCE: chronograph hands reset to wrong places
go to the citizen web site (citizen.com) and select "technical support" and then "setting instructions".
Enter the number off the back of your watch snd the click on "get setting instructions"
The instructions include the steps you need to take to zero the hands.
Anonymous
  • 2501 Answers
SOURCE: citizen AT03060-50E,i bobught online kind cheap
The chronograph will only run for 59 minutes 59.95 seconds.
If you do not have a set on instructions for your watch, you can find one on their web site (citizen.com)
When there, click on "technical support" and the on "setting instructions" and fill in the number off the back of your watch.
Testimonial: "thanks..it helped alot.."
Anonymous
  • 2501 Answers
  • Posted on Feb 22, 2010
SOURCE: the second hand doesn't move
I assume that you do not have any instructions for this watch.
If you enter "www.citizen-signature.com/#/settings/" you should arrive at the page for your watch.
You can download the manual or look at sections.
Anonymous
  • 6771 Answers
  • Posted on Dec 18, 2010
SOURCE: citizen eco drive watch is brand new, but the
You should take the watch back to the dealer for exchange or refund since it would be under warranty, taking the watch apart will void your warranty leaving you unhappy with your purchase.
My big second hand on my chrono watch does not move
Yes that's common, most chronograph watch's a small subdial is the times second hand. The large second hand is only for the timing function of the chronograph.
1helpful
I just recieved a tissot pcr 200 as a gift and the large second hand is pointed to 12 doesnot move the small second dial is working as are the hour and minute hand
your watch is a chronograph or stop watch. the large second hand that is pointed at 12, it is the second hand of the stop watch, it moves when you press te upper right button and it stop on that button too. when it stops the lower button is the reset. i hope i had been helped you.
2answers
How to set up second hand and chrono minutes for bulova 98B105 back to zero setting?
If you haven't got the user instructions you can get them via the following link:-http://www.bulova.com/watches/bulova/marine-star/98b105/
You should see "download user manual" at the bottom of the page.
Want to use larger second hand and set other to zero. have small one working now and the larger one would work if i pressed the top button on side of watch now it wont do anything if i press button dont...
This watch is a chronograph. The true second hand is the one you mentioned that is currently running (what is called the subdial hand).
To use the chronograph hand,
1) Press the button at the 2:00 location to start timing.
2) Press the button at the 2:00 location to stop timing.
3) Press the button at the 4:00 position to reset the chronograph hand(s) to zero.
To reset the chronograph hands to zero, set the crown to either click position one (usually date setting) or two (usually time setting), and use each button to test which subdial hand it will zero out.
Usually it is the first crown click position, and pressing the 2:00 or 4:00 button to zero out.
Warning: Leaving the chronograph function running will drain your watch battery much faster than using the standard second hand, as it is a complication meant for the purpose of timing an activity or other event.
If this does not zero your watch, you must either send it back to Michele, or visit your nearest Certified Master Horologist to assess the issue, as the movement may have a defect.
3helpful
I just purchased an Invicta Sea Wizard Chronograph Watch, and after taking it out of the box I noticed the large second hand does not move. The watch seems to keep time, but the scond hand is frozen in...
The large second hand is actually the GMT hand for a second time zone. The second hand is the small sub dial at the 2 o'clock position. The large hand with the red arrow is the alarm time.
3helpful
Large second hand not running, Stop Watch function?
Hey, it sounds like your watch is just fine! A nice watch to inherit.
The small second hand on the sub-dial is your normal second hand.
The large second hand is the second timer for your chronograph feature.
It should only move when you hit the side buttons. One of them (usually the top plunger/ button) will start the Chrono timer and then hitting it again will stop it. The bottom button should reset the hand to the 12 o'clock/ zero marker.
If the large hand is not functioning at all then there may be something wrong with the watch; perhaps the buttons are not making full contact within the watch or the hand may be stuck and need repair.
Hope this answers your questions. Post more questions if need be.
Congrats on your new watch.
1helpful
ZERO OUT THE CHRONOGRAPH
Here is the manual to help set this chronograph...good luck :)
3helpful
Fossil ch 2470 watch. I have no idea what the extra little dials are for on the face and how to set them. Please help
The dials are part of a Chronograph (stop watch) I assume there is a second, minute, and maybe a date function. Usually the large second hand is part of the stop watch on only moves when you start the stopwatch (top right button) push again to stop and reset back too zero is the bottom button. Usually to set or zero out those dials pull out the crown to the first click (also sets date) then push the top button to set the seconds (big hand) and the bottom button to set the other. sometimes you may need to pull the crown out to the second click (also sets hour and minutes) to set add'l dials. This is generally how you set most chronograph watches the button you push and what moves may be different.
39helpful
3answers
Reset Stopwatch Hands on CL1111 ?
Try setting the crown to position 2 - i.e. the position normally used to adjust the date.  Then use the top and bottom stopwatch buttons to adjust the minute hand and 1/10th hand respectively.
59helpful
13answers
Chronograph hand not resetting to 12 o'clock
for my victorinox, the crown out one position and the reset button (lower chronograph button) changes the minute hand and the top (start/stop button) does the 10th's of a second...crown all the way out and top (start/stop button) does 30 second intervals for the minute counter.
Top Citizen Watches Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Citizen Watch Expert? Answer questions, earn points and help others
