White rubber tube that sits in water resevouir so that as the water level decreases with use the water can still filter through the machine, has come loose. When I emptied the remaining water in the unit it fell out. It has a grey ball on the end with an opening in the ball to let water go through the rubber tube. How do I put this rubber tube back on?
SOURCE: Stopped steaming only releases water into pad
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
ag
SOURCE: cleaner heats up but no steam is coming out.
heatman101
nt
SOURCE: my gold shark pro mop (costco) steams inside the
Hi escada48036,
Sorry to hear about the problems your having with your Shark. One of our experts, heatman101 wrote a tip we have in our files. Here is the webpage for the tip: http://www.fixya.com/support/r5859780-euro_pro_shark_steam_mop_problem
Copy and paste this into your browser and the page will open up for you.
In the tip he describes pulling off the attachment and finding a small hole that comes out of the tank and leads to the hose. From your description, this sounds like what is plugged up. I think once you clear that, steam should flow through fine.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Brown water and white scale are often the result of the water you use in the iron...
If you have scale, white vinegar will clean that...
For brown water, empty the iron, rinse out the insides with bottled water,
and then use the bottled water instead...
Also check out this tip...
Cleaning a Steam Iron White Scale and Brown Water
heatman101
