I have a ibm thnik center ddp 3.7 s\n lkgwf3b and
If you mean that your computer has no display or just a blank screen..Probably there is something wrong with your computer. Try to check all the connections of your computer, especially the power cord of your monitor and display connection from the back of the computer to your monitor and also the power cord of your power supply be sure that it is plug correctly. But if this solution will not work, open your computer and then remove the memory stick and clean the pins of it by using an eraser of a pencil and then put it back. Hope this could help you.. Thanks
