I have the firmware file but i dont know how to install the file to the Panasonic PT-44LCX65 Television
SOURCE: The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
SOURCE: were is the air filter?
The air filter is in front of the tv pop off the front and it is in a screwed panel you can take it off but i vac it out and air dust it out and it works great u need to not smoke around the tv or burn candles around it hope it helps
SOURCE: Lamp indicator flashes red 3 times every 5 secs.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
SOURCE: Light green and pink spots on my hd tv!!!
For the spots....
I had the same problem, first a blue spot then a green spot showed up. I contacted Panasonic Customer Support. They sent someone out and they fixed the TV for free. They reprogrammed the EEPROM chip in the TV. It is a defect. My TV was 4 years old and out of warranty. They came out last week.
So long as it is not happening by something you have done. It will be fixed free of charge. Call them, it solves the problem.
