The power and lights to the machine is on, but pressing the foot pedal does nothing.
SOURCE: Where might I find huskylock 910 instruction manual?
Your local Husqvarna dealer can order a replacement manual for you and may even be willing to teach you to use it for a nominal fee.
SOURCE: Husqvarna 2000 sewing machine foot pedal stuck on but not pressed
you may need to take foot pedal apart and clean it the contacts inside may be dirty and causing it to stick
SOURCE: I need to know how to thread my Viking Husqvarna
You have a great machine. These are hard to thread but once you have mastered it, you'll have many years of great use. The owner's manual has instructions, as well as the inside door of the machine (the door that folds down on the front bottom part of the machine. However, you might want to follow-up with your local authorized Husqvarna Viking dealer. Most are eager to help you even if you didn't purchase the machine from them. Some even have classes on using the serger. You might try several stores in the area. Suggest that it be serviced and cleaned by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
One fundamental tip is to follow the color coding, start with green, then blue/navy, then red, and finally yellow. The sequence is work inside to outside with threading (green - blue - red - yellow). Do not try different order--especially with green and blue -- since the threads build on each other. I have switched yellow and red with no impact but green then blue is always the proper order.
Good luck.
SOURCE: foot pedal doesn't work
You may need a new foot pedal. Find a small applicance repair shop and ask them if they can test the pedal. Take the machine with you.
