Need to wire a power source to unit.
SOURCE: Line voltage Tstat installation Dayton D-F79 elctric shop heater
If I understand your post correctly....You state that you are hooking up a 240v heater and towards the end you speak of removing jumpers...W2 terminals..ect. It sounds to me your trying to us a 24v low voltage thermostat instead of a Line voltage thermostat.That's what I'd take a look at.
SOURCE: Is there a kit to change from propane to natural
Bill, the model number is good, but won't get anybody the part number of the gas valve. Basically, there are 2 issues to address, the pilot orifice size and the pressure regulator. Get the numbers off of the gas valve (OEM numbers, brand) (likely White-Rogers or Honeywell), and search via manufacturer for conversion kit. (Generally a spring and a pilot orifice). Should you locate a kit, be prepared to have someone properly adjust the manifold pressure once installed. Also, as the make things cheaper, sometimes they are built for one fuel or the other and sealed. You may end up buying a new gas valve. Being raised in a propane plant, I recall their skill-set far superior to general HVAC guys (like myself) in this arena. As propane conversions are a part of everyday life for them (temporarily making a furnace run on propane during construction and switching over once the gas line is hooked up), they are probably a good starting point!
SOURCE: I need a manual or
Dayton heaters are a product of Grainger Industrial Supply.They have locations throughout the country, which can help you with the manual. For a location near you go to the following link.
http://www.grainger.com/Grainger/wwg/branchSearchRender.shtml
SOURCE: How do you wire a dayton electric unit heater?
tengo un motor dayton y nesesito darle un mantenimiento me podrian fasilitar un manual de ma
