Need a new driving belt
SOURCE: Need turntable stand replacement...
I was searching the net for the stand and came across a google reference for the stand for 19.95 plus shipping. I have ordered it. Try this link for the stand part.
http://www.bettervac.com/proddetail.asp?prod=SUN%2D84128&cat=293
Good Luck
Dan
SOURCE: I need replacement beaters for a dough hook stand mixer
Information from manufacturer stating replacement parts have been exhausted.
SOURCE: KichenAid mixer parts problem
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212057.pdf
has a diagram of the locking mechanism item 9. The screw you removed was probably item 8. Look at the parts and you should be able to figure out how to get it back together.
SOURCE: My kitchenAid stand mixer is leaking oil. How do I
referring to:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%204176924.pdf
You can see that there are 5 screws holding the upper and lower gearcase together. They pinch the gasket number 26 together and prevent the oil and grease from leaking. Remove the chrome ring by prying gently around the ring. You will see the 5 screw heads. Tighten them and the leaking will stop.
If it still leaks then you may have to replace the fiber washers number 29 which will involve disassembling the lower gear case.
