Question about Lexar FireFly 1GB USB 2.0 JumpDrive - Blue
My 16 GB Flash Drive won't function properly
The first thing I did when I got the drive was test it with H2TestW or something like that, followed by PassMark BurninTest. It failed both tests. It is a Kingston DataTraveler. I tried copying movies to it, and I could watch both of them, jumping to different parts of the movie until maybe a couple of minutes went by, then it stopped working and when I browsed the drive, all the files were corrupt. I have tried it on several different computers, and the one I viewed the movies on has just had a wipe and reinstall, so I'm confident it didn't have any problems... help?
  • 359 Answers
The H2TestW test program gives failures. That means that there are serius errors. Which errors does H2TestW give?
Try to reformat the FlashDrive. If that fails too, the drive is faulty and should be replaced.
Posted on Apr 28, 2017
5 Suggested Answers
SOURCE:
  • 24 Answers
SOURCE: flash drive repair
It sounds like your media is malfunctioning (electronics).
For this type of problem, we offer a data recovery service.
You simply have to send your media to us.
Our technicians will recover your files on CDs and return everything
within 48h. You just need to send us your Lexar with this form:
http://www.lc-tech.com/documents/LC_Technology_Data_Recovery_Service-SD-Eric.pdf
There is a charge for this service, but ONLY if we
are successful. The pricing is on the form. Please note
that the chances of recovery are around 90%.
Eric Beaudoin
ericb@lc-tech.com
1-866-603-2195 ext 103
LC Technology International
Posted on Jun 25, 2009
laikexpert
  • 281 Answers
SOURCE: Lexar firefly 1GB Jump Drive - Can't copy files to jump drive
1.
Update Your Windows Operating System.
2.
Check your computer.
with antivirus and antispyware program.
3.
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
3.a) Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
3.b) Format pendrive
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Posted on Feb 08, 2010
scc2657
  • 90 Answers
SOURCE: All of a sudden no computer will recognize the
These drives do die from time to time. If a comp wont see the drive....it's dameged ...sorry. :(
Posted on Feb 19, 2010
caroldon
  • 17130 Answers
SOURCE: I'm having kingston datatraveler 120 4gb .It is
Check the USB on another PC and if this is not detected on any PC then the memory is corrupt.
In such a case there is not much unless the dealerships helps for a replacement.
Posted on Jul 11, 2011
My 16 gb pendrive is not detected on xp system what shoul di do for this?
Start->Run and type "diskmgmt.msc" then right-click the drive and select "Change drive letter and Paths" and change the drive letter to something completely different like T: or W:.
Feb 28, 2011 | HP 16 GB USB FLASH DRIVE PRO FULL SPEED...
Tip
Test your pen drive / USB sticks with H2testw
H2testw was developed to test USB sticks for various kinds of errors. It can also be used for any other storage media like memory cards, internal and external hard drives and even network volumes. The executable file H2testw.exe needs no installation and can be directly run. It was developed for Windows XP and Vista. It should also work under Windows 2000 but was only tested on XP and Vista. Windows 9x/ME is not supported. You can use the older command line program H2test under these operating systems. The function of H2testw is quite simple: It fills the chosen target directory with test data and then reads it back and verifies it. H2testw does not overwrite or erase any existing data. It doesn’t do any low-level tricks so administrator privileges are not required. If your hardware is working properly H2testw will not harm any existing data. You can download it from here
on Apr 01, 2010 | Computers & Internet
I lost all datas from my memory stick
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Nov 27, 2009 | Computers & Internet
I have a cruzer micro 16Gb flash drive with 14.9Gb
Did you reformat as NTFS instead of the default FAT32? FAT32 can only transfer files up to 4.0Gb in size. If you reformat as NTFS, you can move larger files.
Oct 08, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I bought a 16 gb touch pmp from china and it will not play music
Hi
if you detele all the music from the player and then put in 1 or 2 songs, then play those two songs? do they play?
If they play fine, put in more songs, its very likely that you have been sold a face capasity player, I got a 16GB player from china, it was actually 4GB, everything above 4GB would not play.
read this page, and test your player with the program:
http://sosfakeflash.wordpress.com/2008/09/02/h2testw-14-gold-standard-in-detecting-usb-counterfeit-drives/
Jul 22, 2009 | iLO (2 GB) MP3 Player
Not recognized in windows xp
check it in other ports, another computer,
test with "H2testW"
Jan 28, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Usb flash drive can't be recognize anymore by the pc..
test with "H2testW" , if the program works and tells you you have errors, run "PD V1.08 B3"
if when selecting usb drive and it states to insert disc... it's stuffed.
Jan 28, 2009 | PQI 512MB Intelligent Stick USB 2.0 Flash...
Usb flash drive not recognized when plugged into hub
data is lost,
test with H2testW'
fix with PD V1.08 B3
good luck !
Jan 25, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Write protected and locked files on PNY Optima 2 GB flashdrive
is there a little switch on the side of the usb, if so move it. test with "H2testW"
Jan 25, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Lexar FireFly 1GB USB 2.0 JumpDrive - Blue Logo
893 people viewed this question
Top Lexar Electronics - Others Experts
Joe Negus
Joe Negus
 Mike M
Mike M
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
