Phone system just lost web (netset) interface. Otherwise system is working fine. Tried several different browsers with the same result
This does happen occasionally but is not a typical thing. This means that you have either lost network access to the system or a service on the system has stopped. The system will have to be rebooted to get things going normally again. The preferred method (since you can do it through netset) is to connect to the console port with a DB9 straight through serial cable and open hyperterm or putty and connect to it at 9800, 8, 1 none settings. Hit ctrl r and the system will reboot. if you don't have a serial cable then you are forced to pull the power or switch it off and then back on. CAUTION: you risk a database corruption every time the system loses power without closing the database properly (netset or ctrl r through the console) so do this as a last resort. Also, the system will do a disk scan (except V3001) and will take 15 to 45 minutes to complete before the system will start to function again. DO NOT UNPLUG IT AGAIN WHILE IT IS DOING A DISK SCAN! You can tell if it is doing the scan by looking at the S1 and S2 lights on the Call Processor. During a disk scan, they will be alternating back and forth (like police lights). Wait for it to complete and try netset again. I recommend doing a fresh reboot through netset after it comes back up just to be sure it's a fresh clean boot.
