Do you mean the GE DECT 6.0 30524 corded/cordless phone? For this landline telephone, you can switch a call from one handset to another (or the base) by using the Intercom feature. Press del/int on the handset or Int on the base and choose a handset number (use the CID +/ phonebook -) buttons (if multiple handsets are registered) or select base from the handset. Press Menu/OK to page the other handset or base. Once that device answers the incoming Intercom call, press and hold Del/Int or Int to create a conference call (both handsets or handset and base listening). Press Del/Int or Int to switch from the Intercom call back to the call on hold. Hang up on the first handset if the person on the second handset will continue to speak to the original caller alone. See pages 24-25 of the manual to see the directions. The direct link to the manual is currently https://www.101phones.com/pdf/ge/30524-user-guide-english-f.pdf .
For any landline phone, to forward a call to another phone number, you need to subscribe to a forwarding option with your telephone company. Check their information for initiating call forwarding.
If you have a different 30524 phone, please add a comment with the manufacturer.
Rear fuse box. INT LP 10 amp . there is also INT LP relay in the same rear fuse box .
Fuse Block - Rear
Under the rear seat, on the left side of the floor pan
The INT LP fuse in the fuse block - rear supplies battery positive voltage to the normally open switch contacts of the INT LP relay. The INT LP fuse also supplies battery positive voltage to the INT LP relay control circuit. The fuse block - rear also supplies battery positive voltage to the relay control circuit for the front courtesy lamp. The door modules communicate on a simple bus interface (SBI). When you open any door, the switch contacts of the door open switch close. When a door open signal circuit is grounded, that door module sends a message to the drivers door module (DDM) in order to indicate that a door is open. The DDM sends a class 2 message to the rear integration module (RIM) in order to indicate which door is open. The RIM activates the INT LP relay in order to provide battery positive voltage to the interior courtesy lamps. When any front door is opened, the RIM will energize the FRT CTSY lamp relay grounding the I/Pcourtsey lamps at G302. Depending on which doors are opened, front or rear, the proper interior courtesy lamps illuminate. The RIM provides a pulse width modulated ground to all interior courtesy lamps for the interior lights theater dimming feature. Some of the courtesy lamps are also used as reading lamps, each reading lamp may be manually turned on or off using it's own respective switch
the engine light also is controlled by a problem in the transmission. If there is a problem shifting gears then have an accredited transmission shop look for the problem
your phone should be flashed with another PPM file to restore the tones. to be sure, flash both MCU and PPM. you may have to go to a service center for that.
Turn calculator on. Select [RUN] [EXE].
In run screen press [OPTN] [F6:-->] [F4:NUM] then select the function you want to use. You have ABS, Int, Frac, Rnd, Intg.
caller id,is enabled by your phone line provider , contact the phone company who can do this for you also they do charge for this best to check with them for this .
