The power cells may be bad will not hold a charge. If you are plugged into the house power outlet using the Power Adapter, it could be defective. Check both conditions.
wikiHowhttps://www.wikihow.com > ... > Cell Phones
11 steps
1.
Turn off your Alcatel phone. Tap and hold the Power button until the screen shuts down. When the screen completely fades to black, then it is already off ...
2.
Press and hold the pound (#) key and Power button at the same time for about 3 to 4 seconds. You will be prompted that all the data will be deleted. If ...
3.
Select "Yes" to delete all data. Use the phone cursor on your keypad and scroll down to the "Yes" option. Press the OK button to select it. The OK button is ...
I would recommend you try using a different battery. Since you used different chargers you've eliminated that it's not the charger. Now its either the battery or something internal in the phone. Try the battery and hopefully that's the reason!
Here are two things to try: I- Using the Power button:
1 Press and hold the Power button for at least 4 seconds.
2 Swipe-down the shutdown confirmation screen to the bottom
edge of the display to turn off the tablet.
Using Charms:
1 Swipe-in from the right edge of the display to access Charms.
2 Touch Settings
Turning Off the Screen
Press the Power button to turn off the screen.
Using Charms:
2 Touch Settings
NOTE: If your tablet is in a standby state (tablet is on, but screen is off), press the Power button or Windows button once to turn on the screen.
12
Setting Up Your Tablet
? Power
? Shut down to turn off the tablet.
II- Unplug the battery, wait 30 seconds, then install the battery again.
Hi Esther, You will need to wipe all data and do a factory reset! To do this press the volume up key and the power on button at the same time until the screen lights up!
Plug in with the 4030a's charger or the usb cable from a PC and it will power up. I'm having the same problem and this is now the only i'm able to turn it on aside from pressing and holding the power button hard for about 5 seconds or so
may be doing some activities like miscalling, texting or charging your mobile phone could wake it up for first time and then you need to use third party app for other options of waking.
for alcatel t10 maybe you can try to press the power and volume up button simultaneously and release the button when you see the android logo and there is a red triangle above it and wait till it reboot this might work..we have the same problem but difference is it stays on the lock screen and it never allow me to unlock it if you're experiencing the same problem this reset instructions might not work.
