SOURCE: Euro-pro iron steam genarator model # ep8001
I have a temporary solution that is working: Use WD-40 around the switch. Spray with the straw that comes with the WD-40. Let stand for a couple days, then turn the whole unit upside down and spray again, and let it stand that way for a couple days. If we could get inside, it could be more of a sure thing, but I had given up on mine and when I accidently hit the switch after siting for the last few days, , it came on!
tombowdb
Now for Sears to try to locate the tool that will open the case.
SOURCE: my shark steam iron is leaking when ironing
It is quite possible that this is a defect in the shark G1490F... I had the same problem and it was a crack in the water holding tank caused by tightening the two front screws (hidden) that hold the tank to the base... It seemed fine at first but after a full heating it developed a crack where it had been weakened when it was assembled... I suggest returning it or if warranty is up , throw it away and get something else..
