If you charge your iPad and iPhone when you sleep, they automatically turn back on. Also, if you don't fully turn it off, a notification would turn on the screen.
Try restarting your iPad. To do this, simply press and hold the Sleep/Wake button until a red slider appears; then slide the slider. To turn back on, press and hold the Sleep/Wake button until the Apple logo appears.
If tip above does not work, try resetting your iPad. To do this, press and hold the Sleep/Wake button and the Home button at the same time until you see the Apple logo.
If above tips do not work, the issue could be that the battery is fully depleted. Plug it into a wall outlet for a while and see if your battery holds a charge. Please note that it can take up to 20 minutes of charging before the iPad will start up.
Are you using the charger that came with it? The charger needs to be at least 10watts. A charger meant to charge iPhones or iPods will cause this kind of problem.
Hold the on switch and menu button together for a hard reset. If you can reset it, there may be an issue with your motherboard. If apple doesn't replace it for you, You can get the board at iPad Repair and there is a guide
that shows you how to put in the part at Electronics
Repair Guide.
