Replaced ICM 2wks ago and then CEL came on. Got fault code for TPS, so I replaced TPS. After replacing idle was very high. Driving down highway car died and won't restart. Any ideas?
SOURCE: 2001 monte carlo
do you have spark if you have no spark the crank sensor is bad.do you have fuel presure now. if not check the fuses. nead more info
SOURCE: 2003 Monte Carlo SS Hesitates and Dies after running for awhile
The ck engine light should not be ignored, what sensor was shown to be bad ? Have it scanned again and replace the sensor that is bad if it still runs rough you might want to consider a tune up. Plugs, wires, fuel and air filter's and clean the throttle body with some gumout. It could also be the IAC motor Idle Air Control. Good Luck
SOURCE: 1996 chevy monte carlo problems
try start with starter fluid if starts than need to check fuel filter and pump again turn key and have u or someone listen at tank for hum of pump if hum turn off and open cap to release pressure check fuel filter and or replace if needed turn on pump and check pressure at straider valve on fuel rail by fire wall drivers side if pressure vehicle should start / if no hum at pump check connections to pump and test pump new doesnt mean free from defects repair or replace as necessary
SOURCE: 2001 monte carlo ss coupe die's while driving.
Does it sound like it runs out of gas? Or is it more like it looses ignition? Fuel filter might be pluged up. or Ignition madual maybe going bad.
Tried spraying staring fluid into intake.. Thinking it is spark related not fuel related. Still not staring.
Before it died the RPMs we're jumping all over (from almost 0 - 4000)
