I have a JL Audio 12 inch subwoofer rated at 8 ohms. i have a mono block insignia amplifier at one ohm stable 1-4 ohms. how to i wire it safely? possible?"
Your amp based on what you say would have no problems whatsoever with
an 8 ohm load, not even if it actually has dual 4 ohm coils and you
wire them in parallel giving a 2 ohm load (don't know your particular sub).
Every
good car amp has protection circuits to prevent itself or the speakers from
damage from too low loads so it shouldn't be a problem even if you
screw up with your calculations. A good amp should even be capable of dealing with a dead short on a channel, zero ohms, activating protection of course.
Good luck and don't worry!
Thanks... i was looking up specs. and here are the numbers.
sub - 12w0-8
amp. NS-A1200
here is the link for the amplifier.
http://insigniaproducts.com/products/car...
whats the best way to get the most power?
thanks so much.
ok thanks guys! and i know they are flexible. im pushing about 400w out of my 4 ohm. i got a 8 and a 4 ohm. its kind of a weird set up.
