Hi pdonnelly , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?Hi pdonnelly , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
What I am after is pictures or diagrams showing me how to get to the spark plugs. The job looks not to be an easy one.What I am after is pictures or diagrams showing me how to get to the spark plugs. The job looks not to be an easy one.
You can't post conmments that contain an email address.
What is the problem with the plugs why doyouhave to replace all the time.
and when replacing plugs always make the gap 0.63 it gives you better fuel consumtion and better pulling power
Had difficulty preparing the diagram. Here is a video: How to Replace Spark Plug Wire Set 95-97 Honda Accord - YouTube
I'll try again as you won't be amused by that. Cylinder Firing Orders & Engine Diagrams - AutoZone Hmm, still trying.
4 - 3 - 2 - 1 for the spark plug wire routing of a 1997 Honda
If you need more information on how to replace the spark plug wires on your Honda Accord, you can check out this video tutorial from 1A Auto. It provides step-by-step instructions for properly replacing the spark plug wires on a 1995 Honda Accord V6 2.7L, but the procedure is similar for all 95-97 Honda Accord V6 2.7L models.
Where is the spark plug
In the cylinder head. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Since you are unfamiliar with this process, do these steps one spark plug at a time. Locate the spark plugs; remove the wire's connecting cap from the plug; remove the spark plug from its threaded hole (use a dedicated spark plug wrench or socket of the proper size - may be a 16mm, 5/8", or possibly but unlikely 13/16"); check the electrode gap on the new plug and install it in the threaded hole; follow the plug wire back to its individual coil (opposite end from the spark plug; remove the old plug wire and replace it with the new one of the same length ensuring the same wire routing; replace the plug wire cap on the new plug; move on to the next and repeat.
Things you will need Spark Plug Socket And Wrench of the correct size for your spark plugs
Basic Instructions. Step 1 Locate your spark plugs look for other obstructions besides your spark plug wires if you have any other obstructions you will need to remove them as well to gain access to your spark plugs. Step 2 Remove the spark plug wire for one single spark plug at a time. this will insure you will not replace the wrond spark plug wire to the incorrect spark plug, if not done this way you could change the firing order of your engine. Step 3 With your spark plug Socket and wrench rotate the spark plug in a counter clock wise direction for removing. Step 4 After you have removed your spark plug insert your new replacement spark Plug into your spark plug socket before inserting it into the correct location. spark plug sockets are made to hold on to the spark plug for easy removal and install. Step 5 insert your new spark plug, before you rotate your spark plug for tightening rotate the spark plug a 1 quarter turn in the counter clock wise direction, then start tightening the spark plug by rotating it in a clockwise direction This will insure you will not strip the threads. Step 6 Continue rotation your spark plug in the clock wise direction untill snug, then with just a lil more pressure tighten it up just a little more. be sure to not put to much force on the spark plug after it has been snug, you just have to apply a little more pressure but not to much that could cause it to break. Step 7 After tightening the spark plug replace the correct spark plug wire. then move on to the next spark plug and follow the same instructions.
if you have any other visiable obstructions preventing you access for replacing your spark plugs you will need instructions on how to remove them parts. i have just instructed you on how to remove and reinstall the spark plugs only.
simple if you are familiar with engines remove 1 spark plug wire at a time unscrew spark plug replace with new one put wire back on that plug and continue to the next wire remember do one at a time should only be four plugs on that vehicle
Its a complete guide.It has step by step instructions to replace the spark plugs on 2003 Nissan
maxima.Click the link below and follow the detailed instructions with proper diagrams, to replace the spark plugs:---------------
http://technoanswers.blogspot.com/2011/03/how-to-change-spark-plugs-on-2003.html
This will help.Thanks.Helpmech.
The top of the engine has a cover remove to see ignition coils. Remove wires then coils, plugs are under coils. This is called coil on plug system. Make sure engine is over night cold before you do this, aluminum heads are easy to pull threads when they are hot. Always replace with OEM plug cheap plugs burn out coils !!!
toyota genuine part number is 11193-70010 6pcs for your car you have to buy and open the cylinder head cover and replace all the gaskets on right and left side
