Freezers Logo
Posted on Dec 25, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Freezer temperature went from 0 to 20 degrees farenheit and holding.I had the digital readout, alarm, and temp. setting go out 1 year ago and replaced with inside temp. guage. I have a warrnty on the compressor and frezer coolant and hoses what would my problem be?The compressor is warm and the fan is working.
David Emmel
Level 2:
Sergeant:
  • Expert 295 Answers
  • Posted on Dec 31, 2017
David Emmel
Expert
Level 2:
Sergeant:
Answers
295
Questions
Helped
128405
Points
781
If this is a self defrosting freeze,then it is normal to periodically see an elevated reading during a defrost cycle. At 20 degrees, it was probably ready to complete its defrost cycle and come back on to return it to your cold setting.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
5 Related Answers
Anonymous
  • 447 Answers
  • Posted on Dec 27, 2007
SOURCE: Frigidaire 25' chest freezer alarm goes off eventhough it is very cold
The temp sensor for the over temp alarm is probably maifunctioning if you are sure that the temp isnt rising
Anonymous
  • 150 Answers
  • Posted on Apr 23, 2008
SOURCE: Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
smokeeko
  • Posted on Jun 16, 2008
SOURCE: Freezer will Not Go Below 8 degrees and Alarm keeps sounding
Our manual says it can take our freezer up to 48 hours to get back to the correct temperature. I found that to be the case when we loaded it fully for the first time.
Anonymous
  • 1122 Answers
SOURCE: Dead Upright Frigidaire Freezer
YOU MOST LIKELY HAVE A FREON LEAK AND RUNNING THE FREEZER WITHOUT FREON IN IT WILL KILL THE COMPRESSOR UNLESS YOU UNPLUG IT AND GET IT FIXED,THE COILS ON MOST FREEZERS ARE IN THE SIDE WALLS SO YOU DON'T HAVE TO CLEAN THEM LIKE ON YOUR FRIG.HOPE THIS HELPS-MIKE
Anonymous
  • 11896 Answers
  • Posted on Feb 11, 2009
SOURCE: Freezer Not Freezing Food
there is a circulation fan and also a vent. Either the fan is blowing, or there is a cloged vent.
Does Kenmore Elite upright freezer reach -20 degrees celsius, where is the info?
Best way I can answer this is to purchase the right equipment for the job. A domestic freezer is not designed to work like that, although it may get there in temp it won't hold it. Recovery is slower then the industrial unit you seek. Domestic unit warranties are void if used for commercial settings (i.e. lunch rooms, offices, lab's, etc...) I wish I had a better answer for you but if you need a specific temperature get the correct equipment for the job. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
1helpful
We ve had the Bosch fridge-freezer (KGU3201GB/01) for about 10 years. Suddenly this morning the freezer started losing temperature, which rose to -13 degrees and the alarm went off. We put the...
Hi Robert, sounds like the unit is not defrosting.
Try this to indicate defost issues.
1. relocate food in the freezer, turn the unit off for 2 days and leave the door open, this will allow total defrost.
2. clean, then restart unit with door closed, after and every 2 hours check temp, I feel you may find it will get to its operating temp reasonably fast and should stay there.
If this is the case, I suspect the defrost heater element has failed and needs replacing, this is the most common cause of your type of issue.
Hope that helps and please dont forget to vote. Regards Russ
2 months ago or so, found puddle of water in front of our freezer; about 1 month ago ice cream in freezer became soft. High temp alarm went off a week ago--I've checked the temperature intermittenly and...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Freezer defrost cycle
If the defrost timer sticks in the defrost mode,yes. Normal defrost time is 30 minutes or less depending upon which timer is installed.
If it happens again,locate the defrost timer and turn the dial manually to see if the compressor comes back on. If so,replace the timer.
It is probably on the rear near the compressor. Some are under the front behind the dust guard.
2helpful
My freezer will not hold temperature. Only a year
If what you say is accurate, I would look at either a weak compressor or and issue with the expansion device. (Cap tube, TXV)
What are your pressures and what freon are you using? Does the door(s) seal tight?
Freezer due to brown out then power restored now low temp alarm
The light should reset itself when the freezer gets to less then 18 degrees. If it is still above 18 degrees it will stay on. Now if it is cooler then 18 degrees then unplug the unit for 1 minute and plug it back in once you are sure that it is below 18 degrees. But do not rule out the thermostat. It could have blown out when the brownout happened. To test it jump the wires together and see if the freezer comes on and goes off
No digital readout
Hello derek143
You Said,
I have a Whirlpool upright freezer AFG 371/H there is a digital display and lights and buttons, on/off temp alarm etc running across the top of the freezer. None of this works but the freezer is still freezing. i have no idea what the temp is.
I think you should try unplugging it for 5 minutes and then try restarting it and see if it reset.
Sep 11, 2008 • Freezers
1helpful
Dec 27, 2007 • Freezers
Top Kenmore Freezers Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
