FM radio settings Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source. FM stereo option You can choose between stereo or mono reception when listening to FM radio. Mono may improve clarity where stereo signals are weak. To change between Stereo or Mono reception: 1. Press the Menu button. 2. Turn and press the Select dial to choose ‘Audio Setting’. 3. Select between ‘Stereo Allowed’ or ‘Forced Mono’. FM scan You can choose whether your Elan E3 automatically stops at the next available FM station or the next available FM station with a strong signal when scanning for an FM station. To change the FM scan setting: 1. Press the Menu button. 2. Turn and press the Select dial to choose ‘Scan Setting’. 3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source. Full scan You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and remove inactive ones. To carry out an autotune: 1. Press the Menu button. 2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be displayed during the autotune. When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the last station you were listening to is no longer available, your Elan E3 will tune into the first station in the alphabetical list. Manual tuning To manually check the signal strength of a known channel: 1. Press the Menu button. 2. Turn and press the Select dial to choose ‘Manual tune’. 3. Turn and press the Select dial to choose the channels.
All TV sets go as low as channel 1. Its just that your tv has been preset to skip certain channels because no station was stored on them. All you have to do is go to the unit and manually change the stations with the program button. If on the other hand this does not work try going through the menu button like you want to tune a new station and after tuning a station select it to be saved in position 1 Then you can acces channel 1. Hope this solution has been helpful?
If you have all the cahnnels updated then you will have to manually edit the station list and change the order of the channels. refer to your manual for instructions.
Turn the tv on. Hook up your components, turn them on, go in to tv menu and auto program the stations. It will see that there is a signal on channel 3 and lock it in for you.
I had the same problem. Tech support told me to turn the tv off, then unplug it. Then hold the power button (on the tv - on the bottom of left side) in for 30 seconds and try again. This did solve my problem.
You have to go through the set up guide and reset the information you put in. It may have changed. Afterwards you must run through the auto program. This is a common problem i find with customers.
What you need to do is take the remote, go into the menu, find channel scan and do a channel scan to find all the available stations available on this system. Make sure the TV set is in the cable mode and not antenna mode or you wont get any stations above channel 13.
