I get the same message from 2 different house chargers and the car charger. I have tried three different batteries.I get the same message from 2 different house chargers and the car charger. I have tried three different batteries.
You can't post conmments that contain an email address.
from explanation this means that you are trying to charge your razor with another phone charger , it will not work out for them self because they are not compatible .
what you need to get your razor phone is the type of his own charger ,but if you can not fine it own charger then you will have to go the store together with your razor phone then will help in locating it own charger that will work for with out any damage on your phone
Check a cable connectors clean,restore a phone to factory settings.go to Menu/settings/initial setup/master reset/enter 6 zero ok. and then try to down load,should be ok.
COULD BE THE PHONE BUT MOST LIKELY ITS THE CHARGER, IF ITS AFTERMARKET GET RID OF IT AND BUY OEM, TRY AND TEST IT OUT WOULD A FREINDS MOTOROLA CHARGER SINCE THEY'RE MOSTLY THE SAME CHARGERS AND SEE IF YOU STILL GET THE MESSAGE.
Does it say something like "charger not recognized". I remember having this problem with my razor, and it drove me crazy for several days, then it went away and has never returned. I may have also blasted all the txt messages away to help fix it to. Killing all the txt messages seems to help this phone if its acting up. Definitely speeds up the menu operation. Apparently 250 txt messages is its capacity, even though it will store alot more.
