The Symphonic SR90VE can only record DVD-R discs up to 4x or DVD-RW discs up to 2x.
TheSR90VE CANNOT record DVD-R discs above 4x; DVD-RW discs above 2x; DVD+R discs; DVD+RW discs; CD's; or any discs which are copyright-protected.
Most DVD-R discs on the market today are 16x, and most DVD-RW discs are 8x - neither of which will work in the SR90VE. You have two options for this problem:
Option #1 - Contact Funai Corporation at 1-800-242-7158 for a "Firmware Upgrade CD". This will make the unit compatible with DVD-R discs up to 8x and DVD-RW discs up to 4x. Once you are on the phone with Funai, they will ask you to hit some buttons on the remote to access the firmware version currently installed on the machine so that they can send you the proper upgrade CD. The CD will set you back about $23.00 (includes cost of CD plus shipping). You will still need to locate and purchase DVD-R 8x discs or DVD-RW 4x discs. Try looking at Amazon.com, Disc4Less.com or eBay.com.
Option #2 - Skip upgrading the firmware and try to find a retailer who still has some old DVD-R 4x discs or DVD-RW 2x discs in stock. (Do a Google search for "DVD-R 4x Discs" or "DVD-RW 2x Discs"). Again, your best options will probably be at Amazon.com, Disc4Less.com or perhaps ebay.com.
Either way, do NOT purchase Dual-Layer discs or Blu-Ray discs as neither of these are compatible with this recorder - they must be standard single-layer 4.7gb discs.
All-in-all, this is a high-quality VCR/DVD Recorder, but the technology of the recording media has advanced beyond the capabilities of the machine. Although the older DVD media is still available, you might just consider upgrading to a newer DVD/VCR which utilizes the newer DVD technologies.
I certainly hope this helps - and good luck!
Refer to your user manual for error codes and troubleshooting tips.
If you cant find the error code then please kindly forward the following:
Disk Type:
Recording Device:
Hardeware Specifications:
So sorry for the inconviniencies you are experiencing.
We had checked and sourced for the error codes on the internet and that was why we advised you check your manual.
Have tried getting a CD cleaner? Although such error codes would definitely not be as a result of dirts on your CD lens.
Lastly if the CD you intended to use was a Verbatim 8x "DVD-R", it cannot be reused after a writing session has been done on it..
Try using a DVD-Rewriteable disk and let us know if the same error occurs
The recorder was switched off/unplugged after recording without ejecting the disc. The recorder could not write essential recording information onto the disc.
While REPAIR is displayed, the recorder automatically examines the recorded area of the disc and updates the track numbers and recording time data. This process takes about 40 minutes for a fully recorded disc. Finalization or further recording is possible once the REPAIR message disappears.
The codes aren't in the manual. I talked to customer service last time, and E4 was that the lense needed cleaning. At that time, she told me I could find the codes online. This time, I tried to find the codes, but the only thing I found was this forum. The disc is a Verbatim 8x DVD-R. I recorded about 4 seconds of something on it, and it worked. I then deleted that, so I could record a show. I hit record, it said it was recording. When it started writing was when I got the error. As for the recording device it's the SR90VE, which is where this is posted. I'm not sure what other info would be meant by recording device.
