I managed to take off the top and two side panels. The front panel is loose on the sides and at the bottom. The top of the front panel is "fused" to the rest of the machine. How do I take it off?
SOURCE: Jura Capressa E9 Leaking
Your spout is probly cracked (a common problem). It won't hurt the machine if you want to live with making one cup at a time to catch it all.
If you want to get it repaired go to www.hotncold.com Click on Jura Repair for shipping instructions. We can turn the job around in 24 hours. The repair will also include a free software update.
SOURCE: Jura z5 after filling system said coffee ready
Someone online sells a special screwdriver head used to open the Z5. With it, it's possible to take the machine apart, clean up the coffee ground dust that gums up the moving parts. You can giggle sensor switches that get stuck. The water lines will need decalcifying eventually, even if you use the the Clearyl water filter cartridges. If you're not up to taking machines apart, sell me your broken Z5: [email protected]
SOURCE: jura capresso e9 water not coming through spout
Use a pin or a needle on the spout to clean the nozzle head. Most of the time this is due to useing to fine a grind in the machine. You may have to clean the head this way more then one time to get it to start working again properly.If you have any further questions message me back.
Thank you
Rick
