LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
White smoke out of the exhaust indicates moisture (water) in the exhaust. If the car is not driven very far each day, some moisture will collect in the muffler and cause white smoke for a short while after starting. If the smoke is continual, however, you need to watch you coolant level as you may have a blown head gasket.
Have someone watch the pulleys while you crank the engine.
It sounds like the tension idler is not turning, not an uncommon problem with the 3200 series motors.
The bearing goes bad or the plastic starts to crumble.
If it stops or shows smoke to the person watching, replace it and the belt and you should be good.
smoke doesnt necessarily mean the valve seal is bad, check the valve cover breather. sometimes they plug up and **** oil up from motor. start it up and watch inside of carb for oil dripping.
Oil. if the smoke is coming from between the engine block and the firewall then its probably oil on the exhaust manifold. Make sure that your engine is not leaking oil from the seals and make sure the oil cap and dipstick are in place, start your car, with the hood up and observe the smoke if its bad then id take it to a mechanic but if its only mild then providing your engine isn't leaking oil it should burn off within a few minutes of the engine being started, i say watch the smoke because if it is leaking oil onto the exhaust in great amounts then it is possible it could catch fire.
You will need to replenish the charcoal as it burns down. You can also add some soaked wood chips or wood chunks at the same time for additional smoke flavor. It you are using the water pan it would be a good time make sure it has plenty of water also.
Watch your temperatures and when you see it start to drop, add more fuel to keep the temps up.
Does the smoke occur all the time? If it is present just after start up and then goes away, it could be no problem at all. There is always some condensation in the exhaust at start up. It is more noticeable in cold weather.
However, if it is there constantly, and you are losing coolant, it could mean there is a headgasket problem. Watch your coolant level and watch your temperature gauge. If the coolant starts disappearing, and the car starts overheating, stop it immediately and get it to an auto repair shop. Driving a car with a bad headgasket can cause major engine damage.
