I have put the belt back on but it came off again
SOURCE: hotpoint aquarius 1300
it takes a fitting stap to fit but can be put back on by hand little tricky but can be done no probs
SOURCE: hotpoint aqurious leaking at front
Carefully check the door seal for any sign of a hole or tear in the seal.
Or it could be leaking from the drum front or the drum front seal, this is another seal , not the door seal., you cannot see this without removing the front panel.
SOURCE: my hotpoint aquarius wmf720 keeps flashing either door or f-10, can anyone help??
Please read in full before attempting
any repair. p.s. Before working on machine "turn of the
power". When machine is turned upside down, the
hose has a tendency to come off.
Only carry out if you are confident that you can carry out safely.
Note check small black hose to the air pressure switch is connected,
If unsure call a service engineer.
My machine just had the flashing "door" fault.
On carrying out fault finding checks,
I Found that the main PCB had a built up dust.
This dust was in black lines going between components of the board.
Cleaned around components of the board with a small soft brush.
assembled & tested okay 2 months ago & still working.
