First Option: mostly nokia chargers doesn't make problems... just try the following.. connect ur mobile with a system (usb cable)... found out whether it is charging or not... if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)... if it charged with usb cable buy a new charger Please change Phone Bettery and check the charging IF Charging Problem not Solved So
Second Option: Your Phone charging IC Fault So Please change charging IC And charging Problem will Solved Quickly
The spec say it has a built-in microphone. If you are using Windows, open the sound controller and check that the slider on the microphone is turned at least half-way up. When you open the sound controller (speaker in the systray next to clock), the microphone is normally muted. To test, unmute and tap the microphone or speak into it. Make sure you have the volume turned up on the speakers too.
The dv1000 notebook is equipped with:
1 Type I/II PCMCIA card slot. I store my Media Remote control. (left side)
1 IEEE-1394(Firewire) (right side)
3 Universal Serial Bus (USB 2.0) (Two on the right side and one on the left)
1 Built in 6-in-1 digital media reader (No Compact Flash)(Right Side)
2 headphone-out (front)
1 microphone-in (front)
1 TV-Out (S-video) (right side)
1 RJ-11 (modem) (left side)
1 RJ -45 (LAN) (left side)
1 External VGA monitor port (left side)
expansion port for use with HP Expansion Base(sold separately).
Available only with Intel Extreme graphics with productivity port (left
side)
asuming the 8s are 4ohms each; wire two in series and that gives you 8ohms then two more in series then you put those together in parallel and it gives you a 4ohm load. repeat with other four for the other side. you should then be able to bridge the sub
series; posative of one speaker to negative of other speaker and that doubles your ohms
parallel; posative to posative negative to negative and that cuts the ohms in half
Hi.........i have a compaq presario 700 series.In my laptop if i plugged my headphone into my laptop the lap speakers cant stop working,both laptop and headphone speakers are working
