It works completely fine but when I pull more cable out or pull the hose to move it further around the room, it goes off. Then comes back on 'low' when I stop pulling it. I then have to push the button to get high power again. I don't know why it does it.ive always had a Henry but fancied a change to a hetty. Is this meant to happen or shall I return it as faulty? It's only a month old.
SOURCE: henry hoover cuts out
A 5amp fuse will struggle on start up on anything over 1000watts. Check the rating plate on the appliance for total load
SOURCE: my hoover smells of ammonia
I too have a problem with a bad smell coming from my henry hound hoover, but thats probely because i haven't used a hoover bag. I took the cloth filter out,banged all the dust off, then sprayed it with 'RugDoctor' pet stain remover for carpets and upholstery. It still smells a bit, but not half as bad as befor. I have now ordered a reusable,zipable,washable cloth hoover bag especially made for Henry's. It cost £8.80 from ebay with free postage. Hope this helps Nikki.
SOURCE: numatic henry keeps cutting out & plug crackles in the socket!
It wasn't the hoover, it was the plug socket!
SOURCE: My Old Henry hoover is making a VERY loud noise
Most likely the motor bearings have worn out. You can fit a new motor quite easily, but if you need to pay someone else to do it for you the labour plus motor cost will probably make the job uneconomical. Sorry to be the bearer of bad news...
SOURCE: Rewiring a Henry Hoover
no it wont work it wont make any difference , the field coil connections have to be altered , suggest buy a george it has a place to screw the pipe on to blow
