When the wash cycle ends on my GE WSM 2480 washer/dryer combo unit the clothes are still dripping wet. When I run the spin cycle with the door held open (manually depressing the sensor) the spin cycle seems very slow no matter how long I let it spin. It doesn't seem to spin in high speed. What could be causing it to spin but only at the slow speed? What's the best way to fix and how much might it cost?
SOURCE: Clothes wet, doesnt spin fast
Check the drain spigot, where the drain hose attaches to the drain trap under the sink/tub.There may be a blockage in the spigot which is causing the water to drain very slowly and therefor not allowing the machine to spin at normal fast speed.
SOURCE: Brand new GE Profile leaves clothes soaking wet
It is under warrenty call the store where you bought it and have them look at it. If you mess with it it will void your warrenty, belt may not be working or transmisson may not be shifting. The house call will be at no charge.
Testimonial: "thankyou for the help, I thought I had just made a bad buy. They sent someone out right away and it turns out this particular machine had a bad part."
I tried running the washing machine completely empty through just the spin cycle and it still would spin rather slowly.
