The bottom door on the case broke and doesn't stay closed.
How do I get a new case for my iPhone 4? I received the case in March of 2013. I would like to get a new case and or a replacement case. It was ordered from Amazon bought and sold by Amazon
The lower hinge on each door
may have a door closing cam. It raises the door up ¼ inch when opening and this
assist in closing the door. If it’s wore out and doesn’t work the door may not
seal and the gasket can be damaged. Watch the operation of the door to see if
it rises up when opened.
Leave the door shut and let the magnetic gasket hold the
door in place. Put something between the bottom of the doorand the floor to hold it in case it slips. Remove the bracket holding the pin and hinge assembly taking note of
order of removal of parts. Slide new cams on. Part 11 on this diagram is your door closer http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170924&diagram_id=1335988#d1335988
note of order of removal of parts. Slide new cams on. You probably need two.
To replace it Leave the door shut and let the magnetic gasket hold the
it rises up when opened. To replace
