Question about Electrolux EL6988EZX Oxygen Canister Vacuum Cleaner
Power Head is not getting power
The power to the powerhead needs to be reset but, this model does not have an external reset button. The vacuum still turns on and has plenty of suction. However, the head part is not getting power after I accidently got a sock stuck in the brush. I check the belt and it is fine. You can also feel the suction coming thru but, the roller brush does not turn automatically nor do the lights turn on
RJ ROY IS Bald
Posted on Jan 09, 2014
SOURCE:
After removing six screws, how do I get case apart to repair electric cord
How do i replace the power cord on electrolux nimble - Fixya
www.fixya.com/.../t25091002-replace_power_cord_electrolux_nimble
Sep 11, 2014 - Power cord is frayed next to body, need to replace it. how do i get ....See all Electrolux EL8602A Nimble Upright Bagless Vacuum Questions.
Amazon.com: Customer Reviews: Electrolux Nimble Upright ...
www.amazon.com/...EL8602A/.../B004GUFWBM
Amazon.com, Inc.Electrolux Nimble Upright Bagless Vacuum, EL8602A ... The rotating brush on/off buttons are located right under the soft-touch power button high up at .... Cord is a $30replacement part, which I'm regretting not doing from the get-go, due to ...
Apr 13, 2015 | Electrolux EL8602A Nimble Upright Bagless...
Why won't my Hoover Platinum turn on?
Check and see if there is a reset button for the vacuum head this trips sometime to protect the head motor. Also if the roller heads bind they can snap the belt if it is belt driven. If it is direct drive then I would look for the trip or reset button.
May 14, 2014 | Hoover Platinum Lightweight Upright Vacuum...
Living Air Model # XL15
I called with this problem, and after explaining that I did everything I was supposed to do, including vacuuming the inside and outside, cleaning the wire with at LEAST 20 up & down strokes, and cleaning the plates with hot sudsy water, allowing 24 hours to dry and the holding down the power button to reset the unit for 10 seconds; the near-English speaking tech asked me if I had done each step (individually) that I JUST TOLD HER I did. She asked me if I had the original store receipt (which I couldn't find at the time I was on the phone) and then told me that they would send me another one for $29.95 freight plus I would have to pay for return shipping of the original (2-month-old) unit. At this rate of exchange I could just buy another brand new one in less than a year.
Jun 13, 2013 | Air Purifiers
Reset oreck XML professional
The reset button is power button,look at what it says under cell check button, hold(symbol) button t reset.
Jan 27, 2013 | Oreck XL® Air Purifier
The power head on my ocean blue vacuum will not work
Broken wire in hose, connecting power head to the vacuum?
Aug 26, 2012 | Ocean Blue Water Products Vacuum With Air...
Red Light indicator on
I have a Bionaire tower air filter model BAP1700 that I bought from Costco. The filter check LED came on recently after 5 months of use. After cleaning the Permatech filters, I tried every remedy on this website including following the instructions that say push power button for 2 secs. Nothing worked. Then I noticed a tiny hole on the control panel in front of clean filter LED; I pushed a paper clip pin into that hole, felt a click, held it down and 2 secs later, LED went out. Success!
Apr 06, 2007 | Bionaire BAP1500-U Air Purifier
Replace Filter Indicator Will Not Turn Off
I owned the previous model of the same unit with the hole for the paperclip. But it wore out and I replaced it with the HAP422 and found the same issue; no hole to "reset" the light. I was just fooling with it and determined that "some" switch would reset it and finally held the power on button on for a few seconds, after which, the red light flashed and then went out. Problem solved. BUT THERE IS NOT ONE WORD IN THE MANUAL TO TELL YOU THIS! WHY NOT?
Dec 18, 2006 | Holmes Products HAP422G-U Air Purifier
Electrolux EL6988EZX Oxygen Canister Vacuum Cleaner Logo
151 people viewed this question
Top Electrolux Air Purifiers Experts
ray gallant
ray gallant
Tom Chichester
Marvin
Marvin
Are you an Electrolux Air Purifier Expert? Answer questions, earn points and help others
