My Nextbook next8p12 Has 3 wires running to the battery red/black/white. All the replacement batteries I see online only have the red and black. Will they work?
They will, but i don't know if i would trust them. The white wire is the thermistor, its what the charger inside uses to monitor the battery temperature. So in case something goes wrong with the charging it can sense the overheating and stop trying to charge the battery. Will the battery work, of course, unless the Nextbook requires the temp sensor input to allow the battery to be used, some devices won't recognize a battery without a temp sensor input and will say there is a battery fault because its missing, and some will work with it but may or may not even charge it because it doesn't see the temp input when it tries to charge. Best suggestion i could make is try it, but i also would suggest you get a proper battery for it, lithium batteries are scary enough when they fail, not having that safety could be even worst.
