Popping & cracking noises
Is the popping noise coming from the speakers? If it is, lowering the volume to zero does not stop the popping from the speakers, then you have an audio output failure. If the sound is not from the speakers, you probably have a high voltage leak. If this is the case, are you in a moist environment or using the set near a window??
