Sharp AR-M205 Copier Logo
A
Anonymous Posted on Jan 09, 2014
Error code E7 - Sharp AR-M205 Copier
Gift Ntwana
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 66 Answers
  • Posted on Apr 21, 2016
Gift Ntwana
Contributor
Level 1:
New Friend:
Cheetah:
Answers
66
Questions
Helped
18392
Points
83
LSU trouble. Improper connection of the LSU
connector
Check the polygon motor
operation with SIM 25-10.
Check printing with SIM64-1.
Check laser emission of laser
emitting diode.
Check the LSU unit.
Check the MCU PWB
2 Related Answers
Anonymous
  • Posted on Dec 19, 2008
SOURCE: AR-5132 Error code E7 13
netoiyer les miroire de scanner et la bare blanve
Anonymous
  • Posted on Jun 06, 2009
SOURCE: sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
How do i clear error F2-70 on sharp AR-5623N copier machine?
http://printcopy.info/?l=en&mod=erc&brand=Sharp&model=AR5623N&code=F2%2070
Sharp AR5623N Error Codes
Sharp AR5623N Error Codes Code: All codes CH Blink CH ON E7 01 E7 02 E7 06 E7 10 E7 11 E7 16 F2 40 F2 64 F2 70 F2 74 H3 00 H3 01 H4 00 H5 01 L1 00 L3 00 L4 01 L4 31 L4 32 L6 10 U2 04 U2 11 U2 12
Code
F2 70
Description
•Improper cartridge (Destination error, life cycle error) •Identific t ion error •Model error •Type error •Destination error •Data abnormality •Misc error Detail •The destination of the machine differs from that of the CRUM. •The trade mark code of the CRUM differs. •The company code of the CRUM differs. •The boot program model code does not coincide with the CRUM model code. •When the CRUM type is other than genuine/ conversion/production rotation. •The machine destination differs from the CRUM destination.
Causes
CRUM chip defect Improper toner cartridge.
Remedy
Replace the toner cartridge.
What's your question? My Sharp photocopier AR-161 display E7. and can't make copies what is the problem?
Here is a list of error code meanings for your device. You need to find out the sub code should be E7-?? To find the root cause. Sharp AR 161 Error Codes Trouble Codes
E7
E7 03 LSU trouble
E7 04 CCD white level trouble
E7 05 CCD black level trouble
3answers
I have E7 and machine won't work????
E7 sounds like an error code. First step is to look it up in your owner's manual.
E7 ERROR CODE
when the E7 code comes their is sub code u can view it by pressing start key then we can guest how ever i think this is coming from scanner ccd or chick ribbon cable connecting to the mother board from c c d
12helpful
3answers
Toshiba washing machine with error code e7-4
Toshiba top washer machine with error code e7-4. What the problem and how to solve.
16helpful
3answers
Display error code E7
Sharp copier AR5516 not working. Error code E 7 kindly help.
6helpful
Hi my copier displays E7
Check this out :
E7 codes deal with the optical scanner unit and or the laser unit. It could also be the lamp in the scanner unit. The E7 is the main code. There is a sub code associated with it. To view the sub code hold down the start button. Below is a list of specific codes and their meanings:
E7-02: LSU trouble
E7-10: Shading trouble (Black Correction)
E7-11: Shading trouble (White Correction)
E7-12: Shading Trouble
E7-16: Abnormal laser output
If it is a laser (LSU) issue then the LSU may need replacing.
If it is a shading error the first step is to remove the platen glass carefully (with the power off because the inverter board). There is a thin white strip on the bottom side of the platen next to the **** glass. Clean this white strip with a soft cloth and a small amout of isopropyl alcohol.
Dust on the optics can also cause shading reference errors so gently blow off the mirrors with canned air.
Perform the following key procedure to reset error:
"#" key, Interrupt key, "C" key, Interrupt key
"1" key, "4"key
Start key, "CA" key.
See if unit cycles and comes back up. If not turn off and then back on the main power.
If error reappears on site technical service may be required.
3helpful
3answers
E7 problem
E7-02: LSU trouble
If it is a shading error the first step is to remove the platen glass carefully (with the power off because the inverter board). There is a thin white strip on the bottom side of the platen next to the slit glass. Clean this white strip with a soft cloth and a small amout of isopropyl alcohol.
"1" key, "4"key
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
