Hi Dj 019, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
1- Authentication is ON? 2- Port Setting?Hi Dj 019, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
2- Port Setting?
Can you please confirm 1-Authentication is ON/OFF 2- Port Setting 3- Print Job Remain in Queue or gone to printer 4- Blue Light blinks on MFP when you send the print job Yes/NoCan you please confirm 1-Authentication is ON/OFF 2- Port Setting 3- Print Job Remain in Queue or gone to printer 4- Blue Light blinks on MFP when you send the print job Yes/No
You can't post conmments that contain an email address.
Special firmware version (Web browser LK-101v3 support; Filename: GQQ-65 A1610Y0-F000-GQQ-65.exe)
Special firmware version GPQ-65 (Filename: A1610Y0-F000-GPQ-65.exe) Notes:
1. HDD Format will be necessary when CE301 or CED01 is displayed.
2. Please refer to attached Program Release Information prior to installing the firmware.
all colors? check the sponge looking roller right side door in correctly, check print try to catch the printer in doing a job open the right side during a job is there toner on the transfer belt across from the sponge roller. does this happen during copy does demo page and meter count page come out ok, try different file also and program pdf or web page etc.
Sir mam are you sure it is not happening before fixing does your transfer belt (Shine y looking thing inside the machine when you open the right side of the machine) Does it have only one pic finger in the middle is that where the nick is located. I believe you transfer belt is causing it not the fixing unit. Stop a copy before fixing does the nick move on different copies
If not in the direction of the paper feed then in the direction of the scan head. Dirt on the scan head or bad scan head or scan head connection. Send it back.
2- Port Setting?
