Tablet will turn on and off but screen wont do anything. and does not vibrate when turning on/off. blue light comes on on the button but also wont do anything.
I would reset it. some have button in a hole
or turn off hold volume down and power at the same time till menu appears or you vibration then release
or turn off hold volume up and power at the same time till menu appears or you vibration then release
tablets are designed to be throwaway.
you can buy new batteries off ebay but replacing the battery will require cutting and soldering as the batteries in these tablets are soldered directly to the board and are stuck in place with glue and electrical insulating glass tape. Not a big job but fiddly and anyone with a soldering iron skill and basic leccie-tronics can do it.
it may be the battery - when you press the power button does the screen flicker or does the green power light come on.
pressing the power button whilst pressing the up or down volume button should take you into recovery mode - do this whilst the power block is plugged in - if the tablet shows signs of life with the power block plugged in you can be sure its the battery..
when tablets are vroken its usually by being dropped and this can cause the screen connector to come loose so you get no display but power lights will still be on.
Can you get into the settings if so go to the general settings snd you should see reset at the bottom press this and the whole ipad should go back to factory settings . Don't worry about your folders and other stuff you have it wont delete anything hope this helps
Press and hold the power button for about 20 seconds. You should see some flashing. Let go of the button and watch. It should reset it's memory and come back on. If this does not work then call your tablet's customer service.
I would recommend for you to turn the iPad off completely and restart it. To do this you push the power button in the top right until "hopefully the red "swipe to turn off button" appears. If this does not happen we will have to perform a hard reset and the way to do this is to push the power button and the home button at the same time for about 10 seconds. The iPad may restart automatically however if it does now now you can push the power button in the top right and the Apple Logo should appear at the center of the screen.
Now your iPad should start up freshly and come back to life, unless there isn't a further problem.
Try using a paperclip to reset it on the back, hold it in for 5 seconds, if that doesnt work: Turn the tablet all the way off, press and hold the VOL - and power at the same time for 8 to 9 seconds, it will show a green android guy with a system recovery menu. Use vol - to go down to Wipe Data/Factory Reset, press the power button to select it, go down to 'yes' to confirm, press the power button to select it, it will wipe the tablet, you then press the power button on 'reboot system'.
You'll have to factory reset it by turning it off and holding the home button and power button at the same time I know because I got into my hidden setting and accidently turned it on myself
