Old post, doing all 2018,
that is NOT the full model number, why post lacking that
or what OS you run ,windows, what?
ok windows login works, but what is a TILE?
ok this is simple really, you slammed the OS some way.
that means changed OS in wrong way.
NO OS stated, but now the video driver is WRONG
my guess is the resolution is in safe ,mode 800.600 and sure
is no good for most apps. sure.
not known the real name of this PC means I have to look them up backwards at acer.com, a real pain that is.
ok, me fooling about on ebay, it is and
Acer Aspire One AOA150 (for sure)
it came new with XP ONLY, so still running XP the virus magnet
that it?
here it is, click vga and load that.
if you upgraded to Vista or newer this will fail\
click control panel then click system
BINGO your OS is told to you, now , never post
computers questions lacking that KEY FACT, or answers will be wrong or ignored just like this one was for 12 months.
https://www.acer.com/ac/en/US/content/support-product/61?b=1
SOURCE: acer3610 will not start up
ok well as soon as you turn on your computer press alt and f10 and it will return it to the factory default
SOURCE: i cannot access my desktop
As you can see the cursor and also the task manager, I would recommend you to check if there are any programs running in the Applications tab of Task Manager.
If you find any application running, select that application and click on End Task.
If there are no applications running in Task Manager, we will have to check with Processes tab.
Click on Processes tab and if you find any unknow process that is not windows process or system process, select that process and click on End Process to end the process.
The windows processes have the Username as SYSTEM. Even the Local Service or similar other Services needs to be running and should not be ended.
The other process with a different name have to be checked and if you feel that any unknown process is running you can end it.
Also click on Shut down menu in Task Manager and select Restart or Shutdown option and check if your laptop starts normally without the blank screen.
When the unknown process are stopped the system would normally start without the blankscreen.
You normally face this issues when the system does not shutdown properly or due to problem with startup files.
Following the steps mentioned earlier may help you in resolving your issue.
SOURCE: My Acer Aspire won't boot up past the Window's Loading bar
Log in to safe mode by pressing F8 during startup, if you see windows loading you have missed your window to push the F8 key. When the options menu comes up choose safe mode.
While in safe mode if it loads, click Start > Computer (My Computer) > right click on your ‘C’ drive and click properties > click the ‘tools’ tab > click the ‘Check Now’ button under ‘Error-checking’ > make sure the options ‘Automatically fix…’; and ‘Scan for and attempt recovery of bad sectors’ is checked. A dialogue box will come up stating “windows cannot check the disk”, just click the ‘Schedule disk check’ button and restart your computer. When the computer starts up a check disk will start, let it run. you might want to go do something as the check disk may take up to and sometimes longer than an hour.
Let me know if that helped, and please rate me after, thank you.
SOURCE: Resolution change on my lap top screen when I load my webcam
I had this problem on my PC and I tried everything from updating drivers to re installing the software and updating my graphics card but nothing seemed to work.
And then as a last resort I right clicked on the icon on my desktop and chose properties and clicked on the Compatability tab and unchecked on display settings Run in 640x480 screen resolution.
This worked and did not affect the webcam in anyway.
SOURCE: Windows cannot recognize my password.
In case you have problem with your pass log in as administrator (the default pass is blank) and change your account's pass to a proper one. I can't understand what you mean by AR. Could you send me a print screen of your log in screen with the AR? (hit prt sc in log in screen > log in in any account > open Word or any image editor > paste the print screen from the clipboard) My e-mail is [email protected].
Stelios.
If running XP
A log-on loop on your Windows XP computer is a difficult situation where the computer never completes its boot cycle, restarting intermittently ad nauseam.
This issue indicates a major problem with the boot functionality of your XP system.
Restore the computer to working order by utilizing the repair and restoration utility on your XP system disk.
Insert the XP disk into the computer.
Restart the computer.
Press any key when prompted to boot from the disk.
Press "Enter" at the first screen and "F8" at the license terms.
Highlight the drive containing XP and press "R," repairing the operating system boot files and removing the log-on loop.
or
Windows XP sometimes has a glitch when you are logging in to your user account in order to boot the operating system.
The glitch logs you in and then logs you off the account.
This problem is usually caused by one of the programs that load during the computer's start-up.
Fixing this issue is a matter of ensuring that whatever program is causing the problem doesn't start up as soon as you start your computer.
or
Power on the computer and allow it to get to the user logon page normally.
There is no need to start up the computer in "safe mode."
Click the user who is having the issue and type in the user's password if one is set up.
Press and hold the "shift" button on your computer keyboard as soon as you see the tool bar load up at the bottom of the screen but before any other program has a chance to do so.
This stops any "Startup" program from running and logging you off.
Right-click the "Start" button on the bottom left of your screen.
Select "Explore" from the menu that appears.
Double-click "Programs" from the list on the left side of the window that pops up.
Double-click "Startup."
Select all the files inside the "Startup" folder by dragging a box over them.
Right-click anywhere on the selected files.
Select "Delete" to delete those files.
Note that deleting the programs from the "Startup" folder does not delete them from your computer.
All this does is make it so that these programs no longer start as your computer is starting so that any error in the running of the programs doesn't interfere with logging in to your account.
Hope this helps
or
or
Hope this helps
or
or
Hope this helps
what security code??if you are refering to change your security password
click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password
also
When you boot up to the log in screen type in administrator as user to log in if you cant log in during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also click start control panel user accounts on the users tab,click the name of the computer administrator you can change the password there
Hope this helps
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor pissword you can change or remove your pissword from there
also
hope this helps
Login With the Administrator Account in Windows XP Professional
Click
the "Start" menu and then click "Log Off."
Click
"Switch User" when the prompt screen opens.
Press
"Ctrl," "Alt" and "Delete."
Click
on "Administrator" when the "Log on to Windows" screen pops
up. Type in the administrator password, if applicable.
Click
"OK." You will now be logged in as the administrator.
Log On as An Administrator in Windows Vista
Start your computer and
allow it to continue through its startup process. By default your computer will
simply load directly to the primary user account (usually the administrator
account), but if there are multiple users on the system it will load to the
account login screen. Use the mouse to
click on the administrator account from the list of available accounts to log
on. This step is only necessary if you've customized Windows Vista with more
than one account or you have set the operating system to load the login screen
first. Enter the password
required in the password field to log on to the administrator account. Click the
"OK" or "Log On" button once you have entered the password.
This button may be labeled differently depending on the version of Windows Vista
or any GUI (graphical user interface) changes you may have made.
Log on as an administrator from within the Windows
Vista environment by clicking on "Start" and then "Log
Off." As soon as you have logged off, you will be returned to the login
screen where you can choose the administrator account from the available list.
If this answer helpful please vote me. Good luck. Thanks for using FixYa
