SOURCE: no power to hot tub...
In all liklihood, your problem is a breakdown in the insulation of the heating element. The elements tend to be mineral insulated then metal jacketed. Once you get a bit of corrosion on the jacket and a little water gets into the mineral powder, it's insulation properties fall off sharply, shorting out the power supply.
There are two practical ways of testing this:
The pro way of doing it is to borrow a high voltage insulation tester, disconnect the power leads from the element and check the resistance between one of the elements terminals and the jacket. Treat anything less than a megohm as a failure requiring replacement of the element. (nb. This is one of those rare cases where you need to use a proper insulation tester - an ordinary multimeter often fails to find this problem)
The alternative is just to replace the element and see how much difference it makes.
A.
SOURCE: hot tub breaker tripping after shorter and shorter
Breakers can grow weak---replace with new breaker.
