It will fill up with hot water but will not go into the rinse cycle cause it needs the cold water. We live in Ohio and have had freezing cold temperatures the last few days and our washer and dryer set out in the garage. The cold water is working in the house everywhere but the water line is run out into the garage. It makes a humming noise when you put it on rinse cycle so thinking the the cold water valve is either froze or went out. Not 100 percent sure and was also wanting to the know the location of the cold water valve.
The cold water valve is at the end of the hose at the back of the machine
if the cold water pipes run outside to the garage , it is a fair bet that the water in the pipes has frozen
easy to check --take the cold water hose of the tap and see if it runs
if it runs replace the solenoid for the cold water valve
SOURCE: Rinse cycle doesnt work
the humming noise is probably the cold valve operating but no water. check tap not turned off. slowly loosen cold water feed and check if water present
SOURCE: Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
SOURCE: ROPER RAS6233KQO T.L.W.-Won't fill/rinse with cold water
Most washers have a small screen at the water inlet valve. They can be accessed simply by revoving the hose from the back side of the washer, using a small screw driver you can carefully remove the screens and clean them out under a faucet.That may be all that is wrong.
SOURCE: Frigidaire washer hot water only
sundsas if you have a bad temp select switch. only selecting hot/hot
SOURCE: water temperature control not working
the fill hoses are backwards,,,reverse fill hoses...on the job...also your under warranty ..call for service but you can do it your self..
