Been charging all night and the power light is still on on the wall charger but no movement in the chair
SOURCE: We have a Jazzy 1113
The battery of the chair is dead. It will say its charged but then when you take it off it will die.
You have to replace the battery.
I had the same exact problem with my father.
SOURCE: My Jazzy won't move.
If your batteries are truly charge they should read around 24.5 VDC. And if the freewheel lever is engaged and you still have no movement your probably need to get into a service tech. Also check the circuit breaker on the chair.
SOURCE: Jazzy 1113 Power wheelchair. Batteries are fully
Yes, the main controller module can be very expensive to replace. I would take it to a reputable dealer if the battery replacement does not help.
SOURCE: Jazzy 1103 will not charge. Power cord and
The battery charger is only made to last 1 year if you
re lucky. They are all made in China very cheaply and some only last a matter of months. If you are on Medicare they will replace the charger if necessary after a year. Good luck, hope this helps
SOURCE: chair no longer charges, no flashing or blinking, lights,
The number of lights that are blinking indicate what the problem is.
Visit this site to locate the type on controller on your power chair and
you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer
for service. If your insurance purchased they power chair for you, they
may also cover the cost of repairs.
