The "I-tent" on my Sunbeam SG6622RP Grill should come off for maintenance by unscrewing two screws, giving me access to the burner. But the screws are corroded and too soft to remove with a screwdriver. What do you suggest?
Just had the same problem... I sprayed some WD-40 on both sides to loosen it, then used a damaged screw remover to pull it out. On one side, the head snapped off and I had to use the smallest-size extractor to directly pull out the shank, but it worked.
http://www.4grabit.com/
BTW, you don't happen to have the instruction manual, do you??
I just did the same on my 94. You have to remove the clips that hold in the grille, after un-fastening them, pull up on the grill to get it off of the truck. Also as a tip, put the fastening clips back into the grill, first, instead of in the frame. That way, all you have to do is pop the grill (with fastening clips in place) back onto the body. This gives you access to the headlight. There are four small screws on the trim around the headlight that hold the light in place. Be careful with the screws, they are very easy to drop and lose. Then, you can simply unplug the light, pull it out and replace it.
Neutronv6 -- Thanks, I'll try the damaged screw remover idea. I do have a manual. I considered WD-40 but held off because of the highly flammable environment that I'd be spraying in.
