Question about Canon PowerShot Cameras
How to repair canon powershot sx50
If somebody has an experience because of a fall got stuck sx50 onto the setting in motion of optics, I would receive it with a big joy. The optics is afraid half centimetre stirs ahead then comes to a halt, and it would be necessary to move it with strength like that longer what leads to a breakup, Canon it was not able to be moved in a service longer, and like this onto equal one to dismantle neither maybe.
SOURCE:
SOURCE: CANON FAULTY SCREEN IMPORTANT READ ME
Only for the brave, on a warrenty expired camera.
Buy a set of jeweller's screwdrivers.
Make sure it is off, with the lens retracted, and remove the battery and SD card.
Remove the 11 screws holding it together
The metal shell is in two halves that can be pulled apart. The rubber socket cover flap has to be removed once one half is off. A rubber gasket round the eypiece lens may drop off - it is easily replaced.
Hold the inner chassis by the edges.
The lcd screen is held by one screw, half hidden under the wiring to the flash - remove it.
Push the wiring to one side just sufficiently to enable you to hinge the lcd screen up on its flexible printed circuit wiring loom.
Underneath you will see the back of the ccd pod, with a flexibe printed circuit wiring loom pinioned under a metal plate with two Y shaped holes filled with brown gunk, and held down by a torex screw locked with some holt melt adhesive, and two further screws inaccessible under the metal chassis to the right.
I hypothesised these were the contacts that become detatched in hot conditions, and (1) tried to shift the flexible printed circuit minutely from side to side using the hole in it (it didn't move appreciably)and (2) pressed down quite hard in the centre of the metal plate, having supported the chassis from below so as not to damage the lens.
I reassembled the whole thing and it worked immediately, with just a faint light smear down the left hand side of the image (the whole image had been completely smeared, then dark, before) which was only noticeable when photographing in dark conditions.
So I took a gamble and it seems to have worked. If it hadn't I was going to break the glue seal on the Torex screw and unscrew and then screw it up again.
Obviously doing this is on your own responsibility.
Posted on Oct 25, 2008
  • 47 Answers
SOURCE: how to repair lcd screen canon powershot sx110-is
http://digitalcamerarepair.googlepages.com
Posted on Mar 04, 2009
  • 164 Answers
SOURCE: Canon PowerShot SX100 IS Lens Stuck
If the lens does not extend/retract when the camera is powered on, then lens assembly is damaged.
Unfortunately, such Canon SX100 (and the SX110 too) has a very fragile lens assembly, and it's damaged very easily. Most of the times the internal gears, the plastic post guides and the motor are damaged at the same time, so the only solution is to replace the whole lens assembly.
The lens replacement requires a qualified camera repair technician, unless you want to try in repair it yourself, which requires tools (scredrivers, soldering iron, desoldering tool, magnifier glass with light, etc).
Best regards,
Posted on Jul 22, 2009
SOURCE: Canon Powershot SX10 lens error
if ur very sure that the battery is fully charged... first we would advice you to change the batteries and see ...... if that doesnt work... the battery contacts may be corroded or bent and hence not making correct contact with the battery
.... sometimes there cud be dust or sand particles in the lens retraction passage... blow out air in those places..... this cud help a great deal.... I was able to fix a similar problem by wiggling the outermost part of the lens.as its trying to go in....
also try Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
if that doest help
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. turn it off, slip in the memory card and turn it on one last time.
if that doesnt help
Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying the above fixes and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
regards iversh
if you felt i've spent my time for u... a very helpful rating is appreciated...
Posted on Aug 30, 2009
chelseawells
  • 11 Answers
SOURCE: somebody was using my canon powershot g9 and when ...
Camera likely has a common short that comes up on the G9 camera. You just need to get the camera serviced and you'll be back in business again. The site that specializes in service for the powershots is: camerasandparts.com They're amazing if you need help with one of these, that's all they deal with. The good thing with them is they do the correction so that common short never comes back again on the G9. Good luck, that's the place if you need help with a powershot model, they're excellent when it comes to service for these.
Posted on Jun 23, 2010
How does canon sx50 hs power the clock
From the main batteries. If there truly is no separate battery then a capacitor holds enough power so the clock keeps running while you change the main batteries.
Dec 26, 2016 | Canon PowerShot SX50 HS Digital Camera -...
There doesn't seem to be a separate clock battery, how does canon sx50 hs power the clock?
From the main batteries. If there truly is no separate battery then a capacitor holds enough power so the clock keeps running while you change the main batts.
Canon sx50 hs Power button not working
Obviously the battery is not powering the camera. That could mean many things. There is a break-down in circuitry in the camera and you need to turn it in for a professional check-up.
Jun 18, 2015 | Canon PowerShot SX50 HS Digital Camera -...
Disable time and date stamp Canon SX50 camera
Press the menu button, choose Date stamp on the "camera icon" tab, and then choose the desired option.
Mar 02, 2015 | Canon PowerShot SX50 HS Digital Camera -...
Stuck lens on sx50
A stcuk lens on a Canon Powershot, have it serviced so it's looked after properly. For the Canons, your best bet is: www.CamerasAndParts.com All they service are the Canons and they are not expensive at all. Most service repairs through them are $79 - $89, including service for the camera and parts and labor for the repair, plus they cover the shipping back if you're in the united states. They are the new we recommend for the Canons, good luck with it.
Oct 24, 2014 | Canon Cameras
How do I take high res photos
Set the Jpeg quality 'Fine' or shoot in RAW.
Oct 11, 2014 | Canon PowerShot SX50 HS Digital Camera -...
Canon powershot stuck in auto mode
In the menu try resetting to factory settings.
Feb 09, 2014 | Canon Powershot A4000 16mp 3" Lcd 8x...
Lense will not go in and out... message at start up is "lens error, restart camera"
The lens of your camera has been stuck.
You need to go to Canon authorised service center. They will replace the optical assembly.
OR
You can give it to an expert for repair, he can repair it without replacing the optical assembly.
Aug 11, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon powershot falled down
You will most likely need to send the camera in for service. There really is no way to repair this problem on your own.
Since you are not out of your 1 year manufacturer's warranty, you will not yet qualify for the upgrade program, however Canon does offer deep discounts in the Canon Loyalty program for situations like yours once you are beyond the one year manufacturer's warranty.
It may be true that it would cost more to repair than to replace, and that's why the Loyalty program is great because you will at least save a bundle on getting another camera.
Hope this helps.
May 22, 2008 | Canon PowerShot A540 Digital Camera
Canon powershot g3
a common problem is with the 'optical unit' shutter control part.
have to replace the 'optical unit'
Apr 16, 2007 | Canon PowerShot G3 Digital Camera
Cameras Logo
132 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
