Acer Aspire 4520-5582 Notebook Logo
A
Anonymous Posted on Jan 08, 2014
Resorce conflict-pci serial bus controller in slot 01 bus:01, device:09, function:00
5 Related Answers
Anonymous
  • 47 Answers
  • Posted on Jan 04, 2008
SOURCE: Resource Conflict - PCI Network Controller in Slot 02
Hi akwasi,
Try pressing F2 and look in the bios for a setting that says "Load Bios defaults". If you have any PCMCI cards inserted please remove them first and try a re-boot.
Have you added any new components on the PCI bus? If you have you need to make sure that the BIOS is allowed to reconfigure the interrupts. The device in slot 03 is conflicting with the integrated network controller hosted on the PCI bus. Remove the device in slot 3 and all should be well.
Most BIOS manufacturers allow the PC/Laptop to manage it's own interrupts, so ensure the device you've inserted allows for this. If it uses fixed interrupts this might be your problem.
A good manual should details the BIOS setting you can adjust in order to get the PCI controller happy again and allow the machine to POST correctly.
Regards,
Spare head 2
Atiq
  • 257 Answers
  • Posted on Apr 24, 2008
check for an update of bios on acer.com it will fix your laptop problem....
Anonymous
  • 150 Answers
  • Posted on Sep 08, 2010
SOURCE: when starting the laptop acer
If it just started doing this all of a sudden, then it is a good bet that *********** board is fried. If you just installed some memory or a communications card or new drive, then take it out and see if it still does it. If not, check the installation instructions to make sure it was put in right.
alien_x
Mike Hidlay
  • 281 Answers
  • Posted on Nov 02, 2010
SOURCE: I have Acer Aspire 5101
you need to flash your bios with a new version try the laptop manufacture's site.
Anonymous
  • 8909 Answers
  • Posted on May 02, 2011
SOURCE: Bus: 06, Device: 01, Function:
I would firstly reboot and if that doesn't clear the error run www.iobit.com asc.setup utility to remove crosslinked files and sort out a crosslinked registry. Failing that remove the driver from the Control Panel and let the OS set up a fresh driver. Make sure the driver is the correct one!
Resource Conflicts errors for PCI in Slot 01
hey carl - first thing - laptop or desk top - if desk top (tower) remove all slotted cards and boot system - when it boots completely to home screen. shut down and insert 1 card at a time until you recieve you nasty screen. or boot into safe mode f10 or12 get in and disable all your cards -windows system- control panel - then turn on one by one doing a reboot - when you do find the conflicting card you should be able to figure which card or cards they conflict to - you will have to change the resource allocations on probable 2 or 3 cards to allow all to work - there all lots of sites that will explain this better - hope this helped
Bus: 06, Device: 01, Function: 00 ERROR Resource Conflict - PCI Network Controller in Slot 02 Bus: 06, Device: 02, Function: 00 ERROR Resource Conflict - PCI in Slot 03 Bus: 06, Device: 04, Function:...
When starting the laptop acer 5100 it tyries to start and it shows the following Bus 06, device 02 ,function 00 error resource conflict pci in slot 03 bus 06 device 04 function...
6helpful
Al encender mi ACER Aspire 5100 suenan 2 pitidos y en la pantalla me pone: Sistem BIOS Version:V3.13 Bus:06, Device:01, Function:00 ERROR Resource Conflict - PCI in slot 03 Bus 06, Device:04, Function...
You have a n IRQ conflict meaning you have a device that is trying to use an IRQ slot that its not meant to talk on. From the looks of it you have been in the bios already so go back in and set it to factory default.
3helpful
I BOUGHT A USED ASPIRE 3100-5100 MOTHERBOARD AND GET THIS ERROR WHEN IT TRIES TO BOOT. ERROR Resource Conflict ? PCI in slot 03 Bus:06, Deice:01, Function:00 ERROR Resource Conflict ? PCI in slot 03...
You should try clearing the cmos battery. It's a small battery on the motherboard that can be taken off. Take it off for 20 minutes and put it back in. Then boot up again.
5helpful
3answers
Aspire 5100 resource conflict - pci slot 3
Yuor RAM memory conflicts with each other check RAM memory fix same frequency memory into laptop.
Thanks for using fixya.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
