Hi I swear i have a few more greys as a result of this!!!!
- I switched off by removing the battery and put it on charge (switched off over night, all night) - this seemed to fix it
The day after it did the same thing, again i removed the battery and left it out for 10 mins, switched it on and it worked ok - hasn't happened for last 2 days.
I think its a doft ware glitch and haven't found any other info about it yet - samsung website has also been less than helpful.
I sense this is not going to end well, it has died again and now win't work at all.... I'm still waiting for an e-mail from Samsung and sense a phone call to their technical centre tomorrow...toruble is how do i phone them without a phone!!!!!!
You can't post conmments that contain an email address.
Mine has just done the very same and i am incredibly stressed by it! please can you email me if you find a soloution or tell me how you got it mended. i would be very greatful. thanks :)
the way to fix this problem is quite simple on th right side of the phone between the volume key and the play key the top ridge try and jam a small splint of wood inbetween the ridge this raises your screen by a tiny margin but trust me it really does work
It is a hardware problem in this set... there is one solution I found on the
internet...
just follow this link
http://www.handcellphone.com/mobile/forum/screen-freeze
This is courtesy of Helifix from Handcellphone.com...
Hello Guys. I have the same problem and I found out the solution. The
problem is a faulty contact from the touchscreen leading to the phone
board. To be short: on the right side of the phone were the volume
buttons are, under the touchscreen is the screen's contact. Try
"detaching the screens face a little from the phone body exactly at the
volume down button(using ur fingernail or something) and see if the
touchscreen is responding in anyway. My phone has a bad contact there,
and in normal mode all is frozen. Now if I try to pull towards me, the
touchscreen frame from the rest of the chassis, only a mm SURPRISE!! My
touchscreen is working. IF this is your case too...I suggest get a
screw-driver and open the chassis, and trying to make the connection
permanent, somehow. I haven't done this yet, but will do it today. If
anyone is interested I could post the results:) PS: you can send it
back to warranty of a repair phone shop, only to force you to buy a new
touchscreen and pay for the repairs, on a 99% working phone, with a
faulty contact. The choice is yours:)
Hay hay I did it. How I got it to work is thi, pull out the battery on your samsung pixon. switch it back on and continuesly press the ring button. you should get the menu up to ring some one. then start tapping everything. I did this an managed to get the touch screen and the buttons to work! From Sean
it's a problem with the connection between the touchscreen and phone. the m880 is notorious for it. there's a few quick fixes but they don't last long. take it in to get fixed or buy a different phone, mine is six months old, same problem.
