Kenmore 40" Self-Clean Freestanding Electric Range with Two Logo
A
Anonymous Posted on Dec 13, 2017
Restarting after power outage
There was a short power outage and now I can not get the range and over to work. There is power to the range when I turn one of the burner knobs on, but the burner doesn't come on. But all the lights, clock etc come on,but once I turn the burner know off everything goes dark again. How do I reset the range to work?
Michael Edwards
Level 2:
New Friend:
  • Expert 61 Answers
  • Posted on Dec 20, 2017
Michael Edwards
Expert
Level 2:
New Friend:
Answers
61
Questions
0
Helped
21716
Points
153
Turn it off and disconnect all the electric. DO NOT mess with the gas. call a technician. Safety first.
1 Related Answer
Timllfixit
  • 2210 Answers
  • Posted on Dec 29, 2014
SOURCE: we had a power outage and now the oven will not come on the rest of the stove works inckuding the clock the preheat and oven lights come on but the oven does not heat up, we have tried turning off the
My guess is the element in the back of the oven took that moment to die. You will have to get an appliance engineer or good DIY electrician to check the supply to the element to be sure. While you have it out you can write down the serial numbers etc off the label on the back. You will need them to purchase a new element. Just go online to an appliance spares specialist.
Had power outage & when electric company put new transformer on, stove came on with this error f11 error, when open oven door it mesg goes off & on, oven wont work now
I appreciate your post, Katherine!
Based off the information you have provided your Frigidaire range is displaying an "F11" error code after a power outage. An "F11" error code stands for a shorted keypad. I would suggest performing a reset on your range and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not work you may need to have a professional technician out to provide proper repairs. This will prevent you from any unnecessary part purchases. Hopefully this is helpful. -Matt
Kitchaid electric range display PF what to do
PF indicates a Power Failure. Turn off the power supply (for 30 seconds or more) to the unit and then back on, select/touch the range cancel/clear pad and reset the clock. The range should work again, unless there was damage to the control during the power interruption.
When our power went out for about 20 mins & came back on our Maytag stove started beeping and the touchpad display is all gibberish..words, numbers letters etc and none of the buttons willwork. The...
I suggest you study the instruction manual and maybe contact the manufacturer in case there is a reset method.
It shouldn't be overlooked that a power outage is often accompanied by a power surge or a voltage transient or spike capable of damaging sensitive electronics, in other words computers!
Almost everything is a computer these days, which is why every home should have major appliances provided with surge protection and some area protection. Half a dozen surge protectors around the home protecting major appliances will provide a degree of "herd" protection to some of those items without direct protection.
We had a power outage for several days. Now that power is back on, the electric igniter will not work. We have to light the burners manually. There is no "clicking sound" indicating the...
See where the range is plugged in. Check to see if there is power there. If so, the igniter must be replaced. This is not a difficult repair. I would guess there is a power problem, blown circuit breaker, open GFCI outlet or the plug is out.
Gary
3helpful
My schott ceran class top stove keeps saying F1 on it and don't no how to fix it
Here below we have aprocedure to try to see if you can save the ERC.
F1 touch pad / ERC test
This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models
incorporate the touch pad in to the ERC as a single assembly, in which case this
test is not necessary. Simply replace the ERC (Clock).
Warning: If
you feel in any way uncomfortable performing this test or making this repair,
please contact a qualified appliance repair technician.
1. Disconnect
power to the range (unplug the range power cord or turn the power off to the
range at the circuit breaker). It is very important that the power to the range
has been disconnected, so please double check before continuing.
2. Gain
access inside the control panel.
3. Disconnect the touch pad (also called
keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no
lose wires, or anything else that may cause a short when power is turned back
on. Assemble the control panel back the way it was.
5. Turn the power back
on.
6. Wait for at least one hour to see if the F1 code comes back (usually
accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it
does not, replace the touch pad.
Dec 15, 2010 • Cooktops
Cooktop burner switches do not ignite when turned onn
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Thermador cooktop ignitors won't stop clicking
I have the same range top. I am looking for the switch assembly. Do you know where I can buy this part? Please email me if you do. [email protected]
Dec 30, 2009 • Cooktops
Electronic Ignitor would not turn on after the power outage
hi,the problem is i think is totaly shorted coz of power failure.its is sensetive for that power failure or power mulfuction.
GE ZEU36 leds turning on in cascading effect repeatedly when power plant on
50Hz or 60Hz alternator?
circuit board on the stove may be frequency locked
Top Kenmore Cooktops Experts
Kolbrun...
k24674
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
